Electrolux/Dometic Traveller generator - Help needed please
Discussion in 'Tech/Mech General' started by JockandRita, Mar 12, 2011.
  1. JockandRita
    JockandRita Funster Life Member
    Aug 2, 2007
    5,929
    9,029
    Lincs/Cambs border
    Hello all,
    As per the title, can someone help me please, with a problem concerning our Electrolux Traveller 2500H petrol generator.
    Whilst I am able to start it, it will not run continuously, without the help of the choke button, ie, it tries to stall, but when the choke button is operated for a split second, it will continue to run for about 10 seconds and then stall. If I put a load on whilst it is running, (even the smallest load), it stalls immediately.
    So far, I have....
    1..Drained and cleaned the fuel reservoir under the carburettor.
    2..Changed the inline fuel filter and primed it.
    3..Changed the spark plug and reset the electrode gap.
    4..Established a spark, and re-established clean fuel at the carb.
    5..Established a clean burn at the spark plug, (light brown deposits on electrode).
    The same stalling symptoms are present, with or without a clean air filter in situ, and I am now at a loss with the problem.
    Although we don't use it very often, (only 35 hrs running time during three ownerships), as it is a permanent installation, we would like it to function properly, and be available when needed.
    Any ideas or pointers please? Efforts to gain info from so called Electrolux/Dometic generator specialists, have been fruitless. Rolling Eyes
    Regards,
    Jock.
    P.S. In the last couple of hours or so, I have bypassed the tank using a fresh unleaded fuel source, and the problem still exists, which leads me to believe that the problem isn't a fuel quality issue, but may still point to fuel starvation.
    Once warm, the generator will run constantly, and operate the 12v battery charger/Electroblok, and the air conditioning with it's fans, however, if I try to operate the heating element on the air con, or the fridge, or a portable mains fan heater, the revs die off down to an idle, and often it conks out.
    Before I start stripping the carb, (extremely tight working area), are there any other suggestions, or confirmations as to what is causing the problem........please?
    Thanks in anticipation. :thumb:
  2. JockandRita
    Aug 2, 2007
    5,929
    9,029
    Lincs/Cambs border
    Job sorted thanks. :thumb:
    With some suggestions from A N Others, on the other side of the fence, :Wink: I eventually had to strip the carb, locate and clean a partially blocked jet. It was the last thing I wanted to do, as it is a long time since I worked on anything petrol, but I just had to bite the bullet and get on with it. Everything is tickety boo and running sweet as a nut again.
    I've been out there on it all blooming day, and am ready for a hot shower and pint now. :thumb:
    Cheers, :drink:
    Jock.
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,116
    17,785
    YO11 2BD
    A hot pint.....what are you on, drugs !!!! :Rofl1:
  4. scotjimland
    Jul 25, 2007
    28,940
    25,628
    Thought that might be the problem :Wink: ... just wanted to see you sweat a bit .,... :Laughing:
    well done for persevering Jock.. :thumb:
    enjoy your pint of Speckled :Wink:
  5. JockandRita
    Aug 2, 2007
    5,929
    9,029
    Lincs/Cambs border
    Thanks Jim. :Wink:
    Cheers,
    Jock.
  6. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,800
    6,060
    Mansfield,Notts
    I think its a semi blocked Jet:thumb:
    geo
  7. JockandRita
    Aug 2, 2007
    5,929
    9,029
    Lincs/Cambs border
    Ah Geo, my very good learned friend. :thumb: Is that trade or technical speak for a partially blocked jet, but if it isn't, what are the differences, please? (Genuinely, and not taking the pi## at all. :Smile:)
    Cheers,
    Jock.
    P.S. Are we still okay for that locking actuator job at Newark?
