Electrics (1 Viewer)
Locky
32
Kent
3 months and loving it
Help.
for some reason my tv and 12v sockets will not work off of the battery although the lights and hob ignition are fine.
I have cahnged the fuses around but this has not helped. I am not sure if i have the same problem on hook up (i will be checking later today)
On our last trip all were working fine, any ideas on where i should start?
Jon
Douglas
2,835
400
South Wales,
6 years + 5 years in boat before that
I am not to sure if you are saying your 12v TV is not working or your 12v socket is not working or both.
However theer are some 12v TV's that turn of the moment the battery drops to 12v or less, check your battery with a meter.
Doug...
alf
66
South Yorkshire
PVC
Jon,
Have you tried anything else in the socket other than the TV some tvs are voltage sensative and if you battery is low they will not work
Regards
alf
