Electrics
Discussion in 'Swift Motorhomes' started by slocko, Jul 22, 2009.
  1. slocko
    slocko Deleted User
    Our 2.5 year old Suntor 590RS gave us no trouble when it was last used but plugged in cable to charge before going away and immediately blew home electricity. Tried different charging cables, still same thing happened. Re-set in m/home but still tripped. Fridge and cooker still working. Has anyone had this problem, can anyone give any advice please.
  2. SwiftGroup
    SwiftGroup Read Only Funster
    Jan 10, 2008
    108
    Hi,
    I assume when you say it "blew home electricity", you mean it tripped your house RCD?
    If so, I would advise the 230V side of the system is checked out by either your dealer or an electrician, as there is clearly a fault of some type.
    You could assume that as it trips the house RCD, and not the RCD in the motor home, the fault is between the consumer unit in the motor home and the consumer unit in your house, which included the mains inlet (hook-up) and cable.
    I hope that helps.
    Ash
  3. hilldweller
    Dec 5, 2008
    27,505
    26,587
    Macclesfield
    You're not getting much luck with this one. I've no idea what your van is like but the process is the same for any.
    Turn every switch and circuit breaker you can find OFF.
    Switch on one at a time 'till it goes pop - there is your problem.
    If it pops with everything off blame the rats.
  4. WillH
    WillH Funster
    Feb 9, 2008
    1,742
    1,467
    SW Scotland
    Check the cable, I have had a couple of problems in the past with my van and it has always been the cable. Strip out each end and see if there has been any water ingress.
    Rds
    Bill
