OK there's definitely something up with the electrics on my Hymer 544. It has an Elekroblock 104, and a 50W solar panel on the roof.
The problem is that the leisure battery doesn't seem to be charging off the alternator or hook up. I first noticed a problem when I spotted the low voltage LED flashing on the panel.
I bought the van a couple of weeks ago, but what with work and having to keep it in storage most of the time, I've not had a lot of time to spend on it, combined with the fact I have no idea what I'm doing!
I thought maybe the battery was just a bit low, as it had been sitting at the dealers for at least a month waiting for its MOT.
When there was a bit of sun last weekend, it seems that the leisure battery got a bit of charge from that.
However when I plugged it in to the mains, the voltage on the leisure battery didn't change. Same with when the engine is running.
I spent today examining the cabling and checking all the fuses. I found 3 30 Amp fuses and a 2 Amp under the bonnet by the battery. At least one of these seems to go to the habitation area. None of the fuses were blown, but they all had corrosion on the blade tips. I replaced one, and cleaned up the others with emery paper.
The voltage on the leisure battery just now was below 10V - does this suggest the battery could be dead? Or could it just be very discharged?
I ran the engine with the cleaned up fuses, and at first the voltage on the leisure battery jumped up to just over 13 V. I looked at the panel, and the current meter was showing a few amps charging current. Excellent I thought, it was just a few duff fuses! However this was shortlived as I only turned my back a couple of minutes, but when I looked back there was no charging current showing on the meter.
Also, the voltage meter for the leisure battery no longer seems to work. I can get a reading for the starter battery, which appears healthy, but the meter doesn't even light up for the leisure battery. I have been using a multimeter instead. The 12 V lights do work when I turn that switch on.
I'm not sure what I should do next. Should I replace the leisure battery or could this be a wiring issue, perhaps a relay?
All suggestions and advice are appreciated, or just come point and laugh at the newbie!
