electrics HELP!
Discussion in 'Motorhome Chat' started by motorhomer1, Jan 16, 2016.
  1. motorhomer1
    motorhomer1 Funster
    Aug 25, 2012
    31
    9
    Norfolk
    Can anyone help me unravel confusion--I have(woops WE have!) aCompass Avant gard 300 04 plate. When we plug in mains I believe this charges Leisure battery and gives mains for fridge and 13amp sockets. I believe Alternator supplies vehicle battery AND leisure battery.
    The trip box in wardrobe has a trip marked Battery charger .Where is this? and now my friend tells me when blue site supply is plugged in for leisure battery etc it should charge vehicle battery as well????
    Also can I run engine while parked and plugged in to 240 supply as leisure battery getting alternator/ mains charge??
    answers in simple terms please
  2. emmitdb
    emmitdb Funster
    Aug 14, 2009
    1,927
    1,804
    Cornwall
    I can't answer your question re electricity however I can put you right re: your ownership status of the vehicle.
    It's YOURS when there's a problem
    It belongs to BOTH of you when you don't have a problem. Simples.
    Someone with a brain will be along shortly to answer your question
    • Like it Like it x 3
  3. mjltigger
    mjltigger Funster
    Nov 12, 2014
    1,572
    2,572
    Trowbridge
    Not all together on different makes and models but some do charge engine battery on mains and some don't. Most can have the engine running on hook up but some will disable all 12v when tr engine starts and some will even prevent the engine from starting on mains..
    • Like it Like it x 2
  4. andy63
    andy63 Funster
    Jan 19, 2014
    2,325
    8,996
    south shields
    Can't help with charger location and whether vehicle battery charges off mains ,as I'm not familiar with your van...
    There shouldn't be a problem running engene/alternator while connected to mains unless there is a device fitted that prevents it..
    Say to stop you driving off with mains cable connected...
    But electrically I would say it would just be another charging source.
    Ta Andy
    • Like it Like it x 1
  5. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,949
    Our first van was an 04 Autoquest 100 (similar to the Avantgarde 100 which was the little brother of the 300).
    I can't remember where the charger location would be but it doesn't charge the starter battery, only the leisure battery. I fitted a Battery Charge Manager (BCM 12) from CAK Tanks (other types are available) to overcome that problem.
    Starting the engine whilst the EHU was plugged in wasn't recommended as it could cause a problem (can't remember the details now) but I did, inadvertently, start ours once or twice and got away with it.
  6. motorhomer1
    motorhomer1 Funster
    Aug 25, 2012
    31
    9
    Norfolk
    thanks to all for responses,will give GJH BCM12 a go
  7. Badknee
    Badknee Funster
    Aug 25, 2014
    3,836
    17,154
    notloB
    I can only help you from our van. When on EHU I have to switch the charger on (it's in cupboard over fridge). There's switches for pump, gauges for fresh water level and grey water level and lastly a switch that has off in the middle then main and auxiliary. This one I take it as 12v power off and running on main (starter battery) and auxiliary on leisure batteries.
    If I start the engine everything in the hab area goes off except the fridge. My engine does charge my leisure batteries but my EHU does not charge my starter battery.
    Hope that helps. (y)
  8. PeteH
    PeteH Funster
    Nov 22, 2007
    2,245
    2,787
    East Yorkshire
    It`s a bit of a Minefield, Older ones, had "Caravan" style systems, (often by "plugin systems"). and are only a "battery maintainer" type, and not connected to the Vehicle battery. Later ones are more sophisticated, and will charge both Batteries, Mine even has a "solar" connection!!.
    If you can find the manufacturer you may be able to access the website, sometimes the info is there?. In some (most?) caravans the unit is under a seat behind the Fuse/Trip Box?.
    Take no notice of the Avtar, that my Old R-V. and they are a whole different ball of wax!!.
    Good luck
    Pete
