Electricity and the motor home (1 Viewer)
davethespark
20
4
Middlesbrough
Just looking befor buying
Did a three week grand tour of Spain
Hi all we have ordered solar panels(140w) and an extra leisure battery,(2x110Ah) I intend fitting a pure sine Inverter for 240v mains and have 12v sockets in the habitation my question is what is still powered up after starting the engine 240v,12v,or none? the reason I ask is I like slow cooking and wondered if i could run one whilst driving? If so what voltage ?
Cheers Dave C
Langtoftlad
8,860
150,390
Langtoft, South Lincs
WildAx Aurora FB [PVC]
Since 2015
My understanding [which is limited admittedly] is with the engine running you'll have neither 12v [except to the fridge] nor 240v in the hab area.
Your solar should still top up your leisure batteries but not the vehicle battery - unless you've had the relevant box added.
To answer your slow cooker question, I believe some funsters do run one via a small inverter plugged into the dashboard 12v [which is usually only live with the ignition on]
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
You will not have any 230V supplies from mains electricity. If you are referring to the supply from the inverter, it can provide 'mains' power whilst driving. Bear in mind though that if you need to recharge the batteries as well, using the inverter will slow this down (significantly if it is a large inverter running at high load).
Concerning the matter of 12V power in the habitation area when the engine is running, this depends on whether you buy a British or Continental motorhome. The Brits unfortunately comply with a weird regulation (industry, not law I understand) that requires the 12V system to be disabled whilst driving. I have never understood the logic of this. Continental manufacturers have no such qualms and all the 12V systems work all the time the master switch is on. I can use all the 12V sockets and lights in my Hymer whilst driving.
Jan 8, 2013
8,490
11,526
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
If you wire in an inverter with a 13A socket on it you can use that one whilst traveling. Your batteries will get charge from either the engine or the solar panels depending on charge voltage. Just be careful of the wattage of the slow cooker is not greater than the inverter output.
I'm not sure if the other habitation sockets will be live, it depends on the installation and make of van.
DBK
18,009
48,006
Plympton, Devon
PVC, Murvi Morocco
In our British made van all the 12 volt systems work while driving. We use it to run a cool box and the diesel heater for hot water.
JeanLuc
3,304
2,199
Warwickshire
Glad to hear it and apologies for my somewhat sloppy all-embracing comment in the earlier post.
I should have said 'Most British manufacturers comply with a weird standard .......'
Abacist
3,715
10,578
Devon
N & B Arto 88F Tag
since 2013
Sorry @pappajohn probably being a bit dim today but what is the N/C relay, please?
Sep 23, 2013
2,583
8,736
Lincs
Globecar Campscout
'Normally closed'
Contact are closed while no power is applied to the relay, so you have 12V electrics operating. When the van is started, the relay is energised, opening the contacts & shutting off the 12V supply to the habitation area.
Abacist
3,715
10,578
Devon
N & B Arto 88F Tag
since 2013
'Normally closed'
Many thanks for the explanation! Today I have just succeeded in cutting the wire so that our hab electrics will stay on with the engine running but had no idea that this was achieved using an NC relay or that I had cut the wire that operated the relay!
