GeriatricWanderer
- Feb 1, 2015
- 1,194
- 4,199
- Pop-Top Campervan
- 45years
Battery terminal corrosion - why only (mostly) on the negative pole?
That's a very good question! It might be due to dissimilar metals, but should it then not happen on both terminals? However, the positive terminal is often well shrouded so it may be surrounded by drier air than the exposed negative terminal.Battery terminal corrosion - why only (mostly) on the negative pole?
not just one terminal as you can see from these examples.. plenty more images if you google..
Broken Link Removed
