Electrical socket that looks like a small cig lighter socket?
Discussion in 'The Beginner' started by Simon, Aug 30, 2014.
  1. Simon
    Simon Read Only Funster
    Aug 29, 2014
    287
    423
    Ramsgate, Kent
    Hi!
    On one of the sides in our Kon-tiki is a normal UK 3 pin plug socket and next to it is a small circular socket that looks like a cigarette lighter socket, but smaller - about 13mm in diameter.
    Can someone please tell me what the socket is called, and what's available to fit it?
    We're not intending to hook up to the mains too often when we're out and about so if we could get an adapter to fit the socket (I assume it has to be 12v) that will charge our phones from the battery, for example, it would be a great help.
    I already have a cig lighter socket with a USB port that I'm thinking of plugging a USB hub into, but more USB ports wouldn't hurt as this round socket is in a more convenient location than the dashboard.
  2. timdownieuk
    timdownieuk Funster
    Apr 9, 2013
    619
    330
    Ayr
    • Like it Like it x 1
  3. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,669
    7,920
  4. Dave and Ginny
    Dave and Ginny Funster
    Jan 31, 2013
    1,364
    1,514
    Nottingham
    I have exactly the same on mine and it takes a DIN plug as timdownieuk has said
  5. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,320
    17,031
    Liverpool.
    It is a Hella socket. When purchasing plugs make sure they are genuine Hella as there are a lot of Chinese copies about with tin contacts plated with brass. They get hot through poor contact.
  6. Simon
    Aug 29, 2014
    287
    423
    Ramsgate, Kent
    Thanks all, that's the one. I was hoping there would be a big range of superduper accessories to plug into it. I'll go a-searching now I know what it's called. Can't find a mention of it in the book we got with the motorhome!
  7. Simon
    Aug 29, 2014
    287
    423
    Ramsgate, Kent
  8. hilldweller
    Dec 5, 2008
    27,746
    26,834
    Macclesfield
    If you don't fit the appropriate DIN plug on your gadgets, or can't in the case of chargers you buy a converter DIN plug to cigarette socket.
  9. timdownieuk
    timdownieuk Funster
    Apr 9, 2013
    619
    330
    Ayr
    You probably won't find that many 12V appliances in the UK already wired with DIN plugs, you'll have to fit the plugs yourself. I believe that they are more reliable than standard 12V "cigarette lighter" style sockets and plugs (which are pretty awful).
  10. Simon
    Aug 29, 2014
    287
    423
    Ramsgate, Kent
    Cig. lighter plugs are often terrible things; it's rare to find one that fits properly without wiggling out due to vibration. I've found that my bluetooth headset adapter is really good but I was hoping the DIN socket would be utilised more than it appears to be. Oh well, I'll have to look into it further.
  11. Snowbird
    Apr 24, 2009
    10,320
    17,031
    Liverpool.
    I use Hella plugs and sockets for most high power 12 volt items ie, macerator, 12 volt beer fridge, 12volt laptop charger, 12 volt tyre pump, auxiliary fuel tank pump. Cigarette lighter sockets and plugs are just not up to the job.
  12. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,255
    17,925
    YO11 2BD
    Hella plugs are far superior to cig lighter sockets on two points.
    generally rated at 16amps, regular cig sockets are usually 10amps, and unlike cig sockets which rely on friction to hold the plug in, hella use a positive click lock system so making a far better connection
  13. Simon
    Aug 29, 2014
    287
    423
    Ramsgate, Kent
    I'm just wondering where the adapters are that have USB ports, micro-USB charging ports, and outputs to charge laptops?
  14. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,184
    14,126
    Bolsover, Derbyshire
  15. Badknee
    Badknee Funster
    Aug 25, 2014
    3,839
    17,186
    notloB
  16. Badknee
    Badknee Funster
    Aug 25, 2014
    3,839
    17,186
    notloB
    Haha, love it " Hella"
