Electrical problem (1 Viewer)
Coops74
4
Aberdeen
Hi,
Fairly new to this and looking for some advice!
I have a CI Mizar 2007 which was working fine until this weekend. The main battery was slightly down so struggled on start up. Went for a long run so the battery had a chance to charge up but now I don't have any power to the habitation area unless I connect to the mains. I suspect a fuse has blown but not sure where the master fuse is. I have checked the obvious fuses behind the drivers seat but they are fine.
Any advice greatly appreciated!
Daryl
dellwood33
878
Newcastle
italian crap
too long
I don't want this to seem cheeky, but have you switched the habitation power on at the wall switch - on mine it is above the door :Smile:
On mine (2008 Mizar) there is an isolator switch (Red Key ) under the driver seat. If this gets knocked you can loose power to the hab section. :Smile:
peter marshall
2,466
1,704
Cleveleys,Lancashire
Low Line
9 Years
Hi Daryl
different than your probs, but I had trouble with the 12v on my last van it turned out to be a 20amp fuse close to the Hab Batt. Pete
C
Coops74
4
Aberdeen
Appreciate the feedback.
I've checked the panel and switched it on so confident the problem is elsewhere! The isolator switch (red key) is also in the correct position so the problem must be a fuse but no idea where the master fuse is located?
I called my local dealer but can't check it for at least two weeks which is frustrating.
Daryl
dellwood33
878
Newcastle
italian crap
too long
When you switched the panel on, I presume it illuminated and allowed you to select the various options for lights etc ? Is there a particular option that does not work ?
The individual fuses for each option is housed in the fuse box at the rear of the drivers seat
C
Coops74
4
Aberdeen
The panel is not getting any power unless connected to the mains so unable to switch on if running on the leisure batteries. I have checked all the fuses in the panel behind the drivers seat and they are fine.
dellwood33
878
Newcastle
italian crap
too long
Get someone to press the power switch on the control panel while you slowly turn the isolator switch (Red Key) on and off. I had an intermittent fault with mine and only powered up when the key was in the correct position. When the key is right, the control panel should light.
Have you checked the in line fuse at the habitation battery ? it should be under the seat behind the passenger - This could be blown :Smile:
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
since 2007, 25 years tuggin before that.
On our CI there is a large fuse inside a black plastic holder near the leisure battery. Just follow the wire along from the possitive terminal of battery.
dellwood33
878
Newcastle
italian crap
too long
If it is the "Midi" fuse, it will probably be similar to this photo & requires a special fuse.
Link Removed
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
Similar but mines like the one shown on the right here.
Link Removed
C
Coops74
4
Aberdeen
It was the Midi fuse that had blown. What I hadn't realised was there are two leisure batteries, one under the seat in the habitation area which I knew about (no fuse) and a second under the van in a tray which winds out (with the Midi fuse). The positive cable which goes in to the fuse had corroded through causung the fuse to have blown.
Appreciate all the replies as it was a great help in tracing this problem. I just need to repair it now!
Daryl
dellwood33
878
Newcastle
italian crap
too long
Glad you got sorted Daryl :Smile:
Just shows the differences in MHs - our under tray is not used on out model (Even though it is fitted) and both of the Leisure batteries areunder the rear passenger seat - no room under the driver seat as it is full of electrical gubbins ::bigsmile:
