Electrical Problem on 5th Wheeler
Discussion in 'Tech/Mech General' started by MrJinks, Jun 9, 2012.
  1. MrJinks
    MrJinks Read Only Funster
    Sep 1, 2008
    582
    115
    Dorchester, Dorset
    Hi All,
    Fifth Wheeler staying on our CL site at the moment. Has been here for a couple of weeks with no problems. Now every time he attempts to hook-up to electric, it trips out the supply. It even trips out the main house trip for the caravan supply which never normally happens.
    I am no electrician and we have checked the obvious......hook-up lead and plugs checked ok. Tried switching all appliances off ( and 110 volt fridge) to maybe find the culprit but still trips. Even with the 240 volt supply in the fiver isolated it is still tripping at the hook-up point when he tries to hook-up. We have tried other hook-up points and same thing happens but other vans not causing any probs so sure it is his van.
    Any advice before his wife files for divorce :Eeek:
    thanks
  2. acting_strange
    acting_strange
    May 16, 2010
    3,398
    2,568
    North Hykeham
    If you have "isolated" the 240V and it still is tripping then the fault must lie between the input socket and the board.....see if they can see the wiring...has it been chewed by rats/mice etc? Has it ben crushed by something?
  3. slobadoberbob
    slobadoberbob Read Only Funster
    Jun 1, 2009
    6,159
    1,970
    Kent, garden of England
    when I had this issue a few weeks back it was suggested
    A few weeks back it was suggested that my transformer box had failed when I had a similar issue.
    It turn out on mine the main wiring run had been sliced through.. never found out how it happened.. another story.
    Anway.. I spoke at the time to Alex at Calder Leisure and he felt it may be my transformer box... which as we know it was not and Eddie at VanBitz sorted for me.
    But in the process I learned a lot about the RV electronics.. with the help of a multimeter ... removing the top of the transformer I could check the 110v and 240v side... interesting exercise and soon worked out that the 230v spurred off the 110v side of things. But as we know it was a severed cable it was not the transformer.. but that seemed to be the place everyone thought the issue was at... may be worth checking under the lid and see if any burn marks and if you are able to use a multimeter then you can see if you have power at this point of the system.
    Bob
  4. Rob e Lee
    Rob e Lee Funster
    Apr 16, 2012
    435
    511
    Trip
    Does it trip when just hooking up supply cable but not connecting to 5th wheeler?
    Rob
  5. icantremember
    icantremember Funster
    Sep 2, 2010
    5,221
    7,339
    Nr Watton in Norfolk
    Have you tried another hook up cable ....it could be the fault lies in his cable or in one of the connectors
    Brian
  6. MrJinks
    Sep 1, 2008
    582
    115
    Dorchester, Dorset
    Yes, tried that. Thanks :thumb:
    • Like Like x 1
  7. MrJinks
    Sep 1, 2008
    582
    115
    Dorchester, Dorset
    No, only when cable is attached to 5th wheeler. Thanks :thumb:
  8. Rob e Lee
    Rob e Lee Funster
    Apr 16, 2012
    435
    511
    Obviously points to a fault in the 5th wheeler. RCD tripping I assume. Always a pain in the *rse when trying to fault find - usually something innocuous, often caused by dampness.
    In households, washing machines, dishwashers, fridge/freezers are often the reason for RCD to trip.
    Keeps me in work though :Wink:
    Rob
  9. Rob e Lee
    Rob e Lee Funster
    Apr 16, 2012
    435
    511
    Just a Thought
    It could be the cable or connector between inlet and top of fuseboard in 5th wheeler. Just isolating supply inside won't isolate this cable.
    Rob
