electrical lead (1 Viewer)
pamella
146
39
walsall, west mids
c class?
sorryin advance if this is a silly question.
is it possible to make your own electrical lead?
we dont have an outside electrical point and to save trailing an extension lead from mh to outside is it possible to take some orange ehu lead and wire a ehu blue socket to one end and an outside 3 pin plug extension to the other?
then.by using a splitter into the mh ehu point having both this lead and the hookup going into it with the new lead trailing under the mh to where we want it?
or is there a better/easier way of doing it?
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
Yes.
I just made up a short lead with a 3pin plug on one end and a blue socket on the other, and just plug my normal ehu lead into it.
You can buy such a lead ready made from accessory shops.
sean n maggie
672
327
leeds
autotrail
i bought one from shop,,around £6 :thumb:
Terry
11,932
9,073
Lincolnshire
Can't remember ;)
Is this what you mean Broken Link Removed
or this Broken Link Removed
terry
5,408
21,556
Cumbria
since 2011
I made a 3 pin to blue socket up with parts from Toolstation, less than a fiver.
TheBig1
17,619
43,210
the cleanest and a safe way to do it is fit one of these to the end of your hook up lead
Broken Link Removed
then make up an extension lead (coil up cassette ones are good) with a euro plug fitted
Broken Link Removed
or this one made for you
Broken Link Removed
TheBig1
17,619
43,210
bugger, hit post before i added, avoid making up a piggyback with 2 cables into one fitting. they pretty much always leak so can be dangerous especially when it rains
Sep 23, 2013
2,585
8,773
Lincs
Globecar Campscout
The OP should take note that only TheBig1 correctly interpreted what was required - a tap off the incoming EHU lead to provide power outside the van.
Someone else posted a link to one of those splitters recently - probably Techno100 in the 'This week I bought...' thread, but I can't find it now.
P
pamella
146
39
walsall, west mids
c class?
ive found a cable with the relevant plug to push into the splitter and on the other end is outdoor 3 way sockets with the rcd there too.
its so we can use our elec grill and outdoor light.we have no exterior plug and no outside light and the cable would run under the van as we are lhd with the hookup on the drivers and hab door on passenger side.
i do wonder if it would be simpler to have had a light and plug fitted but with the mh being 25 years now dont really wnt to start altering the outside.
thanks for your help.
