Electrical Issues (1 Viewer)
Sep 3, 2013
768
816
Crowthorne, Berkshire
1992 RMB Silver Star 670
One year. A whole one!
Dear all, I have a problem with Udo's electrucs and could really use your urgent help.
I've just taken him out of heated storage for an iminent trip. He was working perfectly last year.
I've noticed one of his two leisure batteries is showing very low on charge. He wasn't out on EHU during storage and now he's on EHU at home, the battery doesn't seem to be charging. There's an electrical Neisch(?) trip thing for each battery and they're fine.
When I connect the EHU, there's an audible clicking as if the system is flicking between things. Not sure what, though.
All electrucs work with the exception of the Webasto. Once that's activated, all it does is blow cold air and the draw from it pretty much disables all other electrical items. I've isolation switches for lights, fridge, sockets, etc and they all go off when the Webasto tries firing up.
The system is trying to charge the flat-ish leisure battery (Optima yellow top) and with the Webasto on, voltage is pretty much showing zero.
Could this be as simple as needing a new leisure battery? The second one is fine.
Of note, however, is that we found the second leisure battery tripping out last year which resulted in it going flat. This also prevented the Webasto not working. This happened a fair bit. We reset the trip, it charged back up on EHU and all was well again. Webasto never failed to work after that. But this happened around 15 times last year.
Maybe I've answered my own question as the battery may have had enough.
However, I would really appreciate your help. I need to resolve this by Tuesday.
43,329
49,441
New battery.
Without doubt, showing zero volts is a certainty.
What I don't understand is, if the two are wired in parallel then both should be flat...the bad one will drag down the good one to the same voltage.
Bellini
Sep 3, 2013
768
816
I'm not sure they are wired in parallel.
Have a good Bosch in my 1973 Series 3 LR. I'll swap with that and see what happens.
Just need to identify which leisure battery is which...
Just to be sure, are there any other possibilities?
scotjimland
2,322
10,013
A Woosh bang
if you only replace one, the old one will drag the new one down
Replace both leisure batteries..
Bellini
Sep 3, 2013
768
816
Fitted a temporary Bosch 70Ah from my old LR and problem solved!
Will buy two new 75Ah leisure batteries now to replace the Optimas.
Thanks to you for your prompt and helpful replies! Much appreciated.
