Electrical fault...The experts are struggling to fix
Discussion in 'Tech/Mech General' started by mf51y, Sep 5, 2015.
  1. mf51y
    mf51y
    Jul 29, 2015
    10
    3
    hereford
    I have a 2.3 2007/8 fiat ducato-Burstner which has in my opinion a wiring loom fault. On two separate occasions the orange engine management light has come on along with the air con failing. It's been in once where a loom fault behind the nearside headlight was repaired however the fault has returned and blown the fuse which powers the odb2 port, air con and air flow meter. The experts are struggling to fix it...all still under warranty as we've only had it a month.
    Anyone had a similar problem I can guide the experts to !!
  2. wizza
    wizza Funster
    Aug 3, 2008
    116
    55
    Essex
    If still under warranty it prob needs a new loom engine harness not repaired
  3. mf51y
    mf51y
    Jul 29, 2015
    10
    3
    hereford
    That's the opinion I came to, I presume the harness comes through the bulkhead somewhere where it's being damaged but a massive job I imagine. We had plans this month which are now on hold...feel well annoyed. After only a few weeks of ownership we feel it's been a bad buy...The problem has been there a while I suspect just getting worse.
  4. mf51y
    mf51y
    Jul 29, 2015
    10
    3
    hereford
    New engine loom being fitted under warranty..fair play they have offered excellent after sales service...fingers crossed all sorted!!!
    • Like it Like it x 2
  5. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,754
    10,173
    it really isnt a massive job these days to change an engine bay loom. each section is attached with multi connectors and can simply be unplugged and swapped out. the issue is likely a bad connection anyway so replacing the loom is a quick fix. if it wasnt under warranty, checking and cleaning all connections is time consuming and expensive
  6. mf51y
    mf51y
    Jul 29, 2015
    10
    3
    hereford
    The Fiat price for the loom is about £650, iam getting them to show me what they have replaced when I pick it up out of interest...The loom must have been chafing to earth somewhere to cause the fuses to go so easy to see on the loom when it's out. Under warranty so grateful iam not footing the bill.
    • Like it Like it x 1
  7. greygit
    greygit Read Only Funster
    Aug 11, 2009
    274
    232
    Forest of Dean, Glos, France and Spain
    Did you get to see the loom?
  8. laird of Dunstan
    laird of Dunstan Funster Life Member
    Feb 15, 2015
    1,304
    3,558
    lincolnshire
    Have you considered contacting the previous owners to see if it was a fault that they had ?
    might have been the reason for them trading it in?
  9. mf51y
    mf51y
    Jul 29, 2015
    10
    3
    hereford
    New engine loom fitted so touch wood problem solved...just a waiting game need to do a few more trips before winter!! I didn't get to see the loom thought about previous owners but I doubt they would say anything ha ha.
