Electrical..2 chargers OK ??
Discussion in 'Tech/Mech General' started by davidallan, Jul 24, 2012.
  1. davidallan
    davidallan Funster
    Oct 22, 2007
    116
    37
    Leeds
    Electical Advice needed...pleeeeeeease:thumb:
    We are thinking of investing in a C.Teck All Singing/Dancing[-Best in the world charger:BigGrin:/B]
    Our M/H is a a' 56 plate Kentucky ..similar to the Rimor BUT the on board Power supply charger has been playing up now and again.....
    If we purchase one of these C-teck chargers and ft it as a permanent onboard unit direct to the battery bank; will there be any possible conflict with the existing m/h 12v supply/charger unit.??
    PS When plugged into the mains campsite/home electrics the existing charger can only be switched off via the rocker switch on the top of the charger unit.....should we do this??
    Many thanks for all your ON-Topic replies :Rofl1::Rofl1:
    David,Liz + Tilly [renamed 'Achmed' the terrorist:Eeek:] a mixed up Terrier thingy
  2. hilldweller
    Dec 5, 2008
    27,221
    26,209
    Macclesfield
    If existing is suspect remove it totally.
    Buy a proper caravan charger if fixing permanently. £80ish on ebay.
  3. davidallan
    davidallan Funster
    Oct 22, 2007
    116
    37
    Leeds
    Thanks for that Brian., Already tried BUT there are Many leads 14 in all coming from this unit and the Display LCD module will not then activate at all:cry::cry:
  4. hilldweller
    Dec 5, 2008
    27,221
    26,209
    Macclesfield
    Oooooooooooerrrrrrrrrr.
    A bit more than your average charger then.
    It's the safest thing to remove a suspect unit.
    But buying a proper charger rather than multi-purpose little unit still stands particularly if you have to press buttons to activate it every time you hook up.
    A proper job one will give you 20A charging, what does little one offer ?
  5. DesRes
    DesRes Funster
    Apr 21, 2012
    260
    110
    West Lancs
    Hi David,
    Agreed with Hilldweller, the SAFEST way is to remove the suspect charger.
    If there are more wires than you understand then take it to someone that does and pay to get the job done properly.
    p.s. "Achmed" sounds fun.
  6. Jill
    Jill Funster
    Jan 19, 2010
    161
    104
    Pembrokeshire
    Did you solve this problem? our Kentucky is playing up and it seems very similar to this?
    Jill
