1. An upgrade is pending. The forum is only accessible in debug mode.
    Complete Upgrade
electric steps
Discussion in 'Motorhome Chat' started by keith walker, Feb 24, 2009.
  1. keith walker
    keith walker Read Only Funster
    Sep 25, 2007
    10
    hi having probs with my steps.new fuse fitted but still not working.the motorhome is a fiat lifestyle can enybody help. thanks keith
  2. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,389
    5,416
    East Sussex 01-580-881288
    Hi keith,
    Most likely a load of road crud underneath but if no joy give our Service Manager Glenn Harris a ring, he will point you in the right direction I am sure.
    Regards
    Peter
  3. C.L.S
    C.L.S Trader - Service & Repairs
    Jul 22, 2007
    410
    49
    Kieth what year is it ?
  4. peter t
    peter t Read Only Funster
    Feb 26, 2008
    155
    Sunny Croydon.
    As peter said from J/ cross more than likely road crud jamming it, mine was... clean it off and put a few blobs of light oil or some grease on the pivot points, voila..... don.t use wd40 as it don't last long enough.:thumb:
  5. keith walker
    Sep 25, 2007
    10
    hi 2004.steps clean no dirt
  6. peter t
    Feb 26, 2008
    155
    Sunny Croydon.
    Ok then , it has a plate attached to one side, linked to the motorarm actuator.. quite easy to remove two small bolts, if you remove it you should be able to manually fold up the step (thats what its designed for) if it folds up ok then at least you know the step is fine ie not jammed.
    That then points to the electric side, could be a supply from the fuse side , motor fault, ...should of asked you can you hear the motor running when you press the button. ??
    Have a look here in the link it's poss one of these models..
    omni step - Google Search
    pete
  7. keith walker
    Sep 25, 2007
    10
    hi pete sorry to mess you about. but the steps were in the closed position when they stopped working
  8. cobmonster
    cobmonster Read Only Funster
    Feb 15, 2009
    56
    Wokingham, Berkshire
    Hi Keith
    The step on our Lunar (Fiat) stopped working with the step out. All sorts were checked and it turned out to be the switch. Ours is the one touch type.
    Tony
  9. purdo4
    purdo4 Read Only Funster
    Jan 28, 2008
    42
    Gloucester
    Help
    Hi Keith,
    Read about your steps.Ours was working fine but for some reason like yours
    has stopped working.Checked all fuses,no dirt underneath,and hubby oiled it.
    Did you get to find out what the problem was.We have a Bessacarr E725 on a Fiat chassis
    so am interested to find out from you if you got it sorted?
    Regards,
    Mo :Sad:
  10. C.L.S
    Jul 22, 2007
    410
    49
    Kieth both the fuse and relay for your model and year are located under the bonnet, roughly in the centre there will be a black plastic cover , they are both there.
    Mark
  11. purdo4
    Jan 28, 2008
    42
    Gloucester
    Electric Step Problem
    just to let you all know, my Electric Step problem was the switch.A wire had come adrift and so would not work.It was great to get it fixed and working again
    Cheers,
    Mo :thumb:
