electric step
Discussion in 'American RV's' started by Hydecolt, May 24, 2011.
  1. Hydecolt
    Hydecolt Read Only Funster
    Jan 7, 2008
    51
    4
    Traveling in europe
    we have a problem with the electric step on a Rexhall Vision,
    normally when the door is opened the step automaticaly comes out... but..
    today when the door opens the step moves a couple of inches then stops, the same happens when you wish to retract it, its as though the power is only at the motor for a second.....has anyone any suggestions,
    thanks Anna,
  2. M1TCH
    M1TCH Read Only Funster
    May 15, 2011
    258
    101
    East Midlands
    Im no expert but it could be seizing try a few squirts of the magic WD40 thats why i like my manual step hope this helps Gray.
  3. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,894
    6,152
    Mansfield,Notts
    Clean and lubricate all the moving parts then pull and push step in and out to assist the motor if it wont move after that, suspect a motor fault
    Bear in mind they get all the road crud thrown at them when running
    If it does free off remove most of the grease/oil you have used as this will attract more muck try to clean up well and use a dry graphite grease to finish of with on the moving bits
    Geo
  4. zaskar
    zaskar Funster
    Sep 25, 2007
    992
    98
    UK
    Hmmmm, when they're good, they're very good but when they misbehave, they're an absolute pain in the butt !:Angry: ........and both of mine were a pain from day 1:cry:
    As has been said, make sure every thing is clean and lubricated cos they get filthy and gritty.
    Remove the split pin and disconect the link from the motor to step and that way you can run the motor and manually slide the mechanism seperately to narrow down which is at fault.
    One of the most common faults with the step is a bad earth connection which will send the control board haywire giving all sorts of different faults which seem to contradict each other wheen you read the step manual. Dont just look at the earth point, disconnect it and clean it thoroughly before reconecting.
    Be very VERY carefull not to have your hands near the mechanism when running. The motor is VERY powerfull for it's size and could easily chop a finger or two off!:Eeek:
    Have a look at this ..............
    http://www.kwikee.com/Adocuments.html#steps
    HTH
    Z
  5. Douglas
    Douglas Read Only Funster
    Aug 22, 2008
    2,837
    401
    South Wales,
    I have in the past had an auto step fail, the fault turned of to be a broken gear, giving similar symptoms, IE move a short distance and stop, both ways. Also I have had the two way switch fail and that gave similar symptoms.
    Doug...
  6. slobadoberbob
    slobadoberbob Read Only Funster
    Jun 1, 2009
    6,159
    1,970
    Kent, garden of England
    yes be very very careful
    Just be very careful if you do test the motor with fingers.. I got my fingers trapped in a coach window wiper motor 30 years back.. it was an up and over motor and the fire service had to cut the motor out of the coach to get my hand free.. not funny.. I was lucky, just a crushed finger... but could have lost it.
    I suspect it is a lot of dirt that is causing your problem as the motor sensor is designed to detect when it hits an object and will stop going about and retract.. I thin you will find it is bunged up and thinks it is an obstruction ..
    For more view try posting it on the RVOC the sister site just for American RV's .. www.rvoc.co.uk it is a free site to register with.. great bunch with 100% yanks.
    But worth checking the earth wire is ground and clean. I spray mine of a couple times a year with WD40. then use a slide out spray on the unit.
    Bob:Eeek:
  7. zaskar
    zaskar Funster
    Sep 25, 2007
    992
    98
    UK
    :Doh: The finger is to push the on/off button, not to do a sword dance round a flailing motor arm! :Doh: :BigGrin:
  8. scotjimland
    Jul 25, 2007
    29,040
    25,728
    Suffolk
    :Rofl1::Rofl1::Rofl1: indeed
