Electric Step stopped retracting automatically (1 Viewer)
N&K
220
42
Berkshire
Swift Sundance 630L
Hi Everyone
I have a "mappa" step on our Autoroller. It has stopped retracting automatically when the ignition/engine is started. The manual operation of the step works 100%.
I have pulled out the fridge vent and found a relay and the wires to the manual in/out switch. The Microswitch on the step looks to be working fine on the underside of the motorhome.
Any ideas on how to get it working again? Could it just need a new relay?
thanks in advance
N&K
Landy lover
2,296
5,928
Zummerzet
27ft Eurolight
Camping Caravaning now 5'ering 49 years
maybe a silly question but have you checked to see if everything else 12 volt is working it could be a fuse - sometimes the manufacturers use in line fuses they can be right b--er to find simple circuit tester might help
43,323
49,427
N&K
two ways to find out.
touch the relay while someone turns on the ignition....you should feel the relay click in.
another way is to find the live feed wire to the relay and the feed wire from the relay to the step motor.
remove from relay and connect them together and turn on the ignition.....if the step retracts the motor's working but the relay is kaput.
relays arent expensive and it could be useful to have a spare anyway.
N
N&K
220
42
Berkshire
Swift Sundance 630L
hi
Everything seems to work, and all fuses are ok in the box. I have just traced some more wiring under the sink, and now I'm off to find my 12v meter. I have opened the relay and if I push the relay manually the step goes in, so I suspect its not getting its signal to retract or the relay is dead. If I find the 12V which goes on and off with the ignition then I assume its gotta be the relay now....cheers.
Thanks pappajohn, there is no click on the relay when the ignition is turned on/started. Once i take a meter reading and see if there is 12V then hopefully just the relay :)
N
N&K
220
42
Berkshire
Swift Sundance 630L
Hi Landy lover & Pappa John
thanks, the 12V signal is there when the ignition is on, but there is no action from the relay. I'll go to Halfrawds tomorrow and let them rip me off for a new one ::bigsmile:
thanks for the quick replies hopefully that will fix it.
Cheers N&K
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
Hi, whilst it is olmost certainly the relay failed the question is why. Increased current drawn because the step is stiff and sticking is probably the answer, make sure you clean, oil/grease as instructed by the manufacturer. don't be tempted to mask the problem by increasing the wattage of the relay.
Good luck.
43,323
49,427
Hi, whilst it is olmost certainly the relay fail the question is why. Increased current drawn because the step is stiff and sticking is probably the answer, make sure you clean, oil/grease as instructed by the manufacturer. don't be tempted to mask the problem by increasing the wattage of the relay.
Good luck.
or the ampage.....
relays are rated in amps roger:thumb:
too low an ampage relay and it will burn out but too high and the fuse will blow if theres an overload fault leaving the relay undamaged.
probably better with a slightly higher ampage relay in my opinion.
you having an off day roger?::bigsmile:
43,323
49,427
Cheers N&K
check the relay earth connection.....remove the earth, clean it and replace.
or run another temporary wire from the relay earth terminal to a known good earth to see if it works then.
