Electric Step "Again"
Discussion in 'American RV's' started by old-mo, Feb 12, 2010.
  1. old-mo
    old-mo Funster Extra Special Life Member
    Oct 16, 2008
    12,805
    39,328
    Hi All.
    A week or so ago I posted regarding my electric step not retracting fully,, thanks to all advise I cleaned and greased all the pivot points and and any moving parts I could see,,, And it works great.. Thankyou.. :thumb:
    Another poser for you,,
    Now wherever I put the switch just inside the door,, the step always retracts when the door is closed.. :RollEyes:
    I am sure when the switch was put in a certain position it used to stay out unless the ignition was turned on,,
    Any idea`s to what problem I should look for ?
    I just want to get it back to = when on site it is permanently out and not retracting every time the door is opened..
    Thanks Again.
  2. madbluemad
    madbluemad
    Jan 26, 2008
    3,341
    243
    spain
    Hi Mo, your right when the rocker switch position is in one position, on mine its up (on) the step says open.
    In the other position (down) it moves in and out as the door opens and closes.
    When the engine is switched on it retracts.
    I think I'd be taking the switch off to check the terminations. And move along from there. There cant be that much that can go wrong, (he says).
    Jim
    :Smile:
