Electric Shock From Kitchen Sink
Discussion in 'Tech/Mech General' started by TeeMyob, Jul 6, 2015.
  1. TeeMyob
    TeeMyob Funster
    Jul 18, 2009
    376
    244
    Cheshire NW UK
    Hi,
    Mrs. TM keeps complaining of shocks from sink on EHU.
    Anyone have any suggestions please?.
    TM
  2. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,374
    9,819
    get it checked by a professional electrician
    • Like Like x 4
  3. laurieash
    laurieash Funster
    Jan 29, 2014
    575
    338
    HALIFAX
    Hab check ?
  4. funflair
    funflair Funster Life Member
    Dec 11, 2013
    4,884
    5,144
    Guisborough
    My guess would be static discharging through the earth when you are plugged in.
    If you dont get the same it would suggest it is a personal thing, or you dont wash up.
    Martin
    • Like Like x 2
  5. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,697
    11,843
    Plympton, Devon
    It might just be static electricity and be down to the carpet or socks she is wearing but you need it checked.
    An electrician could use a megger tester to see if there are any faults in the wiring. It shouldn't cost much for the test which would not take very long - but locating and fixing any fault might be a different matter.
  6. hilldweller
    Dec 5, 2008
    26,907
    25,760
    Macclesfield
    Stop using it on hook up immediately, you just can't take chances with wet and 240V.
    Is this on one particular hookup or more than one location ?
    Anyway do not experiment, if you haven't the kit and knowledge use it do not use the sink on hookup, unless you fancy being a widower.
    It could be worse than just the sink, if there is a fault on the earthing and it's picking up 240V your whole vehicle could be at 240V because it's standing on nice rubber tyres.
    • Like Like x 3
  7. tonyidle
    tonyidle Funster
    Aug 6, 2013
    2,965
    2,798
    Kendal, Cumbria
    Get a simple mains tester screwdriver & check whether there is some mains leakage. Depending on carpets / clothing it could simply be static build-up. If it proves to be mains leakage either get an electrician to take a look or, if competent, connect the sink to a good earth. Personally I suspect static - I'd lend you my wife because she has the same trouble and could tell you immediately what the problem was.
    TBH you can tell fairly easily without any testing: if it's a one-off sudden shock when touching the sink it's static. If there's a continual tickly feeling when holding the sink, and you can feel it too, then it's mains leakage.
    • Like Like x 2
  8. Gromett
    Gromett Funster
    Feb 27, 2011
    7,998
    14,356
    UK
    If it is just one sharp shock when she first touches the sink then it is likely static and caused by footwear or clothing. If it is a continuous issue and may feel like being grabbed a bit then it is probably 240v. If the latter disconnect from EHU /turn off inverter and don't use until sorted.
    I cannot think of any reason for 240v to be routed anywhere near sink in a motorhome. None of my previous vehicles had anything anywhere near them with 240V in. The only electrics near the sink was the lights and these were all 12v.
    My gut feeling is that it is static however it is well worth checking out.
    • Like Like x 2
  9. Gromett
    Gromett Funster
    Feb 27, 2011
    7,998
    14,356
    UK
    Just had a thought straight after I posted. I guess it may be possible for a van to have a 240V oven??? if so then this may have a connection to the sink. Just a possible?
  10. Tootles
    Tootles Funster
    Sep 14, 2013
    9,123
    32,097
    Lancaster
    The very same thing happens to my wife when she's washing her feet in the sink. :(
  11. hilldweller
    Dec 5, 2008
    26,907
    25,760
    Macclesfield
    Our fridge is right next to it.
  12. Don Quixote
    Don Quixote Funster
    Jul 29, 2012
    2,503
    3,705
    Lost in La Mancha, Spain
    REMOVE EHU cable. get your MH checked. Electric shocks CAN KILL.
    • Like Like x 2
  13. Badknee
    Badknee Funster
    Aug 25, 2014
    3,711
    15,943
    notloB
    If she doesn't get a shock when not connected to EHU then it has got to be something to do with that side of it. As has been said it could be earthing out onto the sink but not sure why. In a domestic situation there will be earth straps on the pipe work under the sink (copper usually ) but in your MoHo there will only be plastic.
  14. andy63
    andy63 Funster
    Jan 19, 2014
    1,979
    7,236
    south shields
    Quick read and my thoughts...
    If it only involves the sink and ehu then you have a earth fault with a charge to sink...which would indicate you don't have a an trip on the mains or its not working... If you have try testing it..
    I was thinking if it's a static build up on the person you would have the shocks at other times as well ..
    My initial thoughts ..will have a better read
    Andy..
  15. Judge Mental
    Judge Mental Funster Deceased RIP
    Sep 2, 2009
    6,782
    6,037
    Sarth London
    wear cotton knickers:(
  16. CWH
    CWH Funster Life Member
    Jan 29, 2014
    2,875
    11,484
    under a wand'rin' star
    She "KEEPS complaining"??? She goes back for MORE??? :eek:
    Suggestion: Don't touch the sink Mrs TM!
    Oh, and get the thing looked at by a pro electrician.
  17. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,703
    17,323
    YO11 2BD
    If it was a 230v wiring fault the RCD would trip....or the RCD in the hookup post
    If it doesnt it needs replacing.....as does the trip in the hookup post or house ring if at home..
    My money is also on a static discharge.
    • Like Like x 1
  18. scotjimland
    Jul 25, 2007
    28,934
    25,589
    My money is on a bad or poor earth,
    have it inspected and tested ASAP and don't use 230v until it has been done..
    as posted on another thread.. 'Hot Skin' as the Americans call it KILLS .. even with 110v supply
    • Like Like x 1
