electric problem ?
Discussion in 'Motorhome Chat' started by dennismartin, Oct 29, 2011.
  1. dennismartin
    dennismartin Read Only Funster
    Jul 26, 2011
    135
    19
    hull
    was on site yesterday plugged into ehu turned on heater it lit up the light on the control panel then went out and didnt work thought it had gone wrong so turned it off so turned aircon heater on it went bang with a flash and tripped site breaker as this was first trip out in our van i was a little concerned but had been on test at home for 2 weeks so i plugged it into another site socket and everything was fine i got the site to check there socket and it showed it was ok with there tester any electricians out there can shed any light on this problem :thumb:
  2. hilldweller
    Dec 5, 2008
    27,559
    26,670
    Macclesfield
    Just where was this flash ? How big ?
  3. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,800
    6,060
    Mansfield,Notts
    I saw it in Mansfield:Eeek:
    • Like it Like it x 2
  4. dennismartin
    Jul 26, 2011
    135
    19
    hull
    at back of air con unit away from controls it still works ok
  5. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    sounds like water ingress to the aircon caused a short which was dried out by the first connect/flash. I would be checking for leaks. I would also check your fuse ratings if they did not blow then could be rated too high.
    It could also be a case of overloading the site electrics with inrush current. Caps etc would then be charged and a second connect would draw less current. either way it needs investigation. Fires and motorhomes don't go together.
    • Like it Like it x 1
