Electric Lead (1 Viewer)
Spade
217
64
dethleffs
Still a newbie
H guys
The previous owner when on ehu used to run an extension lead from one of the 240 volt sockets inside the van out through an open window to power items outside the van such as a radio,remorska etc.
This meant that the window was open all the time
SO I have this idea and want to know what you think.
make a double lead with one female plug at one end to plug into the van and at the leads at the other end- a plug for the campsite hook up lead and the extension block wired to the other lead.
Hope it makes sense.
Basically the outside extension lead is connected before the van.
Any thoughts please
Aug 18, 2014
23,772
133,551
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Yes I've go one. Not for use on the MH , although it could be, but used in work situations where you have both blue plugs/sockets & 3 pin equipment.
CWH
5,145
247,399
UK
WildAx PVC
From November 2013
Since we're not competent to 'play' with electrickery - can these be bought?
13,079
101,442
Bolsover, Derbyshire
Hymer S800
not long enough
Or just use a splitter
images
make your own up with leads long enough to suit, then a 16A / 13A sockets
That way you still have the original leads
If I were doing this though I would have the splitter out of sight, somebody is bound to think you are doing something wrong :D and tell you so :)
GeriatricWanderer
1,194
4,199
Ouagadougou, Burkina Faso, just cos I can!
Pop-Top Campervan
45years
images
Like a Caravan Club Commandant.
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
lots of different splitter configurations available commercially from the local camping shop or online, very often cheaper than making them up yourself.
Spade
Spade
217
64
dethleffs
Still a newbie
Thanks so much for all the replies.
I kind of knew it could be done but had never seen it so was unsure if it was allowed or not for any reason.
Thanks again for a great forum
musson
487
165
grantham
low profile
since Jan 2014
Hi i fitted one inside a locker/garage because only used when we were outside, other option outside socket box as post above.
Spade
Spade
217
64
dethleffs
Still a newbie
Have the plugs ordered so will make my own lead.thanks everyone(y)
