Electric in France (1 Viewer)
Gollom
206
122
Preston, Lancs
Hymer B534 (1994) - Hetty
Since 2014
Going French for the first time in September - what power adaptors for hook-up do I need to take to be on the safe side? I am sure E-bay can oblige with the supply!
simbadog
1,683
3,337
Wengen
A/S Broadway EL 2021
Since 2010
Do they have electricity in France? I thought they were still using coal & gas ;)
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
Most French sites have the standard blue plug. A few will have the older white 2 pin plug. Adaptors are available from ebay
Broken Link Removed
or any caravan shop in UK
Kool Kroozer
1,361
2,228
Cannock Staffordshire
Low Profile Hobby Premium
Always learning
I was pretty surprised to see when on aires an campsites recently in france that more sites had english 3 pin connections instead of the euro 2 pin
WynandJean
6,670
3,303
West Midlands
Bailey Autograph 682
Since 2010
Yes, as the others say, the standard blue one is to be found all over France. Only once came across the old 2 pin continental type.
Wyn
DBK
18,022
48,093
Plympton, Devon
PVC, Murvi Morocco
At the risk of opening up a can worms unless you have a MH with modern electrics (twin pole etc) you need to consider reverse polarity. For this you need a reverse polarity detector gizmo and a lead made up to resolve the problem. You probably won't die if you don't but best to be on the safe side.
Apr 27, 2008
11,842
14,071
Hymer low profile
Since 1972
Wyn
It's a funny thing but most of the French vans have the old type lead, so they have to use an adaptor in their own country. Mind you, a lot don't have a proper hookup lead and are using drum extension cables as per B&Q.
Apr 9, 2013
663
373
Ayr
Newbie
Two minutes work to swap wires with a screwdriver if your detector shows reverse polarity.
43,329
49,441
unless you are tampering with an appliance when its still on hookup theres no need to check or cure reverse polarity.
lights still light, fans/motors still turn the correct way....and more important......RCD's and breakers still work as they should.
if you are fiddling inside anything electrical while still plugged into hookup you deserve a shock.
Dec 24, 2009
1,072
15,719
bedworth warks
c class
2009 previously a tugger for thirty years
Also if the plug is of the two pin variety if you check the polarity and it is reverse, just go to the plug and turn it the other way round, ie. cable exiting either up or down! Jobs a good un....
JJ
Mágica
May 1, 2008
19,258
48,043
Burstner Privilege T
over 50 years
Over 40 years of motorhoming...
Never had a habitation check
Never ever been weighed.
Never used a levelling ramp.
Never been gassed
Never been moved on.
Never had a problem with reverse polarity.
JJ :cool:
Apr 27, 2008
11,842
14,071
Hymer low profile
Since 1972
Never been gassed
JJ :cool:
Could add Never paid a site fee ::bigsmile:
