Electric Hook Up At Home
Discussion in 'The Beginner' started by terryandelaine, Jul 15, 2014.
  1. terryandelaine
    terryandelaine Read Only Funster
    Mar 29, 2014
    50
    27
    Malton
    Is it okay to leave the van hooked up to the electric at home for long periods of time, ie a couple of weeks? I am sure I have read on here somewhere that it's not a good idea but can't find the thread again, or maybe I just imagined it.
    Hubby has had van hooked up for a week and I don't want to say wrong thing!
    Elaine
  2. Terry
    Terry Funster
    Dec 27, 2007
    10,769
    6,290
    South yorks
    Mine is on 24/7 when not being used --just keep a monthly check on Battery fluid levels (y)
    terry
  3. Rob e Lee
    Rob e Lee Funster
    Apr 16, 2012
    438
    555
    Surrey
    I always have ours permanently hooked up at home - never had a problem.
    Rob
  4. terryandelaine
    Mar 29, 2014
    50
    27
    Malton
    Brilliant, thank you.
  5. SuperMike
    SuperMike Funster
    Apr 28, 2010
    1,078
    1,232
    St Albans
    If you were on site, away for a couple of weeks or more, what's the difference. (y)
  6. Spottycatz
    Spottycatz Read Only Funster
    Feb 17, 2013
    452
    486
    Racodorm
    Mine's been on EHU for almost two months and will be on for another three as we go to the US tomorrow. :D
  7. cmcardle75
    cmcardle75 Read Only Funster
    Jun 8, 2012
    670
    263
    Reading
    Check if you've got a smart multi-stage charger before leaving on 24/7. Otherwise, you can wear the batteries and will need to spend time topping up.
    • Like it Like it x 1
  8. hilldweller
    Dec 5, 2008
    27,540
    26,625
    Macclesfield
    Shame on you woman. Sneaking behind the back of He Who Must Be Obeyed and questioning his omnipotent judgement.
    Now that you have seen the error of your ways, repent on your sins and never do it again.
    • Like it Like it x 3
  9. Welsh girl
    Welsh girl Funster Life Member
    Nov 7, 2009
    2,744
    1,332
    living the dream.
    People leave their vans hooked up most of the year when on seasonal sites, not much difference to leaving it hooked up at home except you are paying for the electric.:)
  10. SomeoneElse
    SomeoneElse Funster
    Apr 22, 2013
    584
    386
    Cotswolds
    I now have solar panels, so no longer use EHU at home.
    When on EHU the battery monitor showed a constant voltage of 13.7V and a charge current of 0.1A. That's into two 105AH batteries, I assumed the current was close to the internal discharge, so could be left connected indefinitely without damage to the batteries.
    Incidentally, my power monitor showed the EHU was taking about 8 Watts.
  11. wanderer
    wanderer Funster
    Apr 14, 2008
    446
    417
    huntingdon
    I leave mine on hook up 24/7 for the last 6 years but use a timer set at 3 hours per day never had a problem yet
  12. Wombles
    Wombles Funster
    Oct 28, 2013
    2,587
    1,889
    SW England
    Think it's necessary for some electric input when you have manufacturer engine immobiliser & any kind of fitted alarm that runs off the battery otherwise flat engine battery or security system might not work when you need it . We have ours on EHU when covered & not in use but just topped up off solar panel (with Battery Master) for the rest of the time. Know that there are covers on the market with clear roof sections that allow the solar panel to work but would have to be bespoke so just too much money! Not sure how much electricity trickle charging the battery on EHU uses though especially over the winter when hardly used - we left a greenhouse heater on in our caravan when not in use & although low wattage as it was on all the time it added up to an extra £50 on our electricity bill! The timer idea sounds good.
  13. terryandelaine
    Mar 29, 2014
    50
    27
    Malton
    Think this must be the kind of thing I had read. Thank you for the information.
  14. terryandelaine
    Mar 29, 2014
    50
    27
    Malton
    Ha ha. It pains me to say this but he is always right, so annoying!
  15. hilldweller
    Dec 5, 2008
    27,540
    26,625
    Macclesfield
    So comforting.
    You can enjoy your little wifely duties without a care in the world.
  16. cmcardle75
    Jun 8, 2012
    670
    263
    Reading
    Charging at 13.7V is very slightly on the high side for a float. 13.5V would be more comfortable, but you'll probably be OK, especially if you keep an eye on water levels.
  17. camocam1
    camocam1 Read Only Funster
    Aug 28, 2012
    1,112
    783
    Elgin,Moray,Scotland
    think the difference between leaving on at home rather than on site for long period is that on site you will be using the power so not just charging the battery but don't think it will do any harm and as said provided you keep a check on the battery then should be okay.
