electric fan heaters
Discussion in 'Motorhome Accessories' started by niterider, Mar 12, 2013.
  1. niterider
    niterider Read Only Funster
    Jan 5, 2012
    9
    4
    peterborough
    can anyone tell me the best fan heater to use in a 4 berth motorhome. i have a gas heater but find it noisey
    Tony
  2. hilldweller
    Dec 5, 2008
    27,558
    26,665
    Macclesfield
    Then a fan heater is not the way to go. I've searched for tens of years to find a quiet one only to realise they don't exist.
    How about oil filled ?
    • Like it Like it x 2
  3. Gooney
    Gooney Funster
    Jun 2, 2010
    4,772
    7,864
    Flintshire
    Look at the dyson bladeless heater/cooler customer reviews on Amazon, expensive but does get good reviews:thumb:
  4. maz
    maz Funster
    Jan 26, 2011
    2,540
    2,177
    Out there somewhere
    A fan heater might be quiet relative to the gas heater tho' - or at least less noticeable because it's a constant background whirr rather than the assorted clicking/whooshing/variable fan speed noises that you tend to get with gas heaters. I use a Dimplex fan heater as a booster in very cold weather and hardly notice it. It's very good at providing a quick warm up. :Smile:
  5. tofo
    tofo Funster
    Oct 1, 2007
    6,669
    6,516
    Kirby cross further from londin
    if you must have one
    use one with a thermostat
    at least it will be silent sometimes
    never found a quiet one when i was
    at work company used to buy them in bulk
    best price but always thermostat models
    (by the container as it was cheaper than picking them up and servicing them)
    for the vulnerable if we cut the mains gas supply off
    all the ones i gave out had thermostats on and were two kilowatt
    be carefull on site one of them and a kettle pits the electic off
    found out the hard way:Doh:
    first time out in the self build
    still use one in the swift
    parked up during travel i use the gas propex heater
    mrs t will not wild camp
    :thumb::thumb::thumb:
  6. MikeandCarolyn
    MikeandCarolyn Read Only Funster
    Mar 18, 2008
    2,171
    1,463
    Worle,North Somerset
    Firstly,fan heaters are very directional.
    I have been looking for one with more than 2 heat settings because on ACSI sites with only 6Amps many fan heaters are just too powerfull.
    Tonight we have put our Truma on and I must say that it is quieter and the heat is more 'spread out'
    Mike
  7. cmcardle75
    cmcardle75 Read Only Funster
    Jun 8, 2012
    670
    263
    Reading
    Oil filled are silent, very effective and often have lower power settings for limited EHUs. The only issues are that they are heavy and take a long time to get started.
    Some of the quieter fan heaters are the ceramic types, which are also smaller, lighter and more inherently safe than conventional fan heaters. But there'll still be some noise.
    Also consider flat panel convectors, which are thin and easily wall mounted.
  8. andyman
    andyman Funster
    Sep 23, 2007
    1,155
    512
    Leicestershire
  9. Ed Excel
    Ed Excel Funster
    Nov 27, 2012
    869
    577
    Ribble Valley
  10. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,942
    3,401
    Eastbourne East Sussex
    I have a fan heater as an addition to the Truma to reduce gas usage when on hookup. (TRuma output is very low on electric only so gas still needed if its very cold)
    I wouldn't use it on its own though as it will heat the van very unevenly and it will be freezing in the washroom (normally the warmest place).
  11. Terry
    Terry Funster
    Dec 27, 2007
    10,771
    6,291
    South yorks
    I/we have always had leccy fan heaters and either truma or propex heating :thumb:The old DIMPLEX fan heater was good but the new one is crap there is too much difference between heater coming on and off about 10 yes 10 degrees :Eeek: Also tried about 3 others :Sad:This year I bought a Delongi digital fan heater from Lidl about £20 ish and this has proved to be very good turning itself on and off within 2 degrees :thumb::thumb::thumb:Also it has a remote control :thumb:and I RECOMEND IT TO ANYONE :thumb: not taken lightly recomending but so far it has prooved great
    terry
  12. niterider
    Jan 5, 2012
    9
    4
    peterborough
    electric fan heater
    Thanks everyone for your advice i shall be going to currys at the weekend to checkout there stock of fan heaters thanks again
    niterider
  13. Ann&MikeMancs
    Ann&MikeMancs Funster
    Oct 25, 2014
    105
    72
    Salford
    BIG thanks
    Plenty to think about
    mike
