electric circuit tripping out
Discussion in 'Tech/Mech General' started by rob kinnear, May 2, 2011.
  1. rob kinnear
    rob kinnear Read Only Funster
    Nov 29, 2010
    175
    31
    Swansea
    2002 swift sundance electric circuit will trip out after about an hour with the heater on 2000w power level and no other load on the circuit. My question is does this mean there is a problem with the heater or trip switch. The main van trip switch does not trip out.
    Rob
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,946
    17,609
    YO11 2BD
    probably a 10 amp hookup supply which will give around 2300watts.
    there may be nothing else plugged in but are you sure nothing else is connected......onboard charger, fridge etc ?
    these could take you to the limit.
    could be a weak/faulty MCB on the post though....try another post.
  3. rob kinnear
    Nov 29, 2010
    175
    31
    Swansea
    Thanks pappajohn fridge and charger run off a different circuit which has never tripped out and the post is 16amp.
    Rob
  4. pappajohn
    Aug 26, 2007
    29,946
    17,609
    YO11 2BD
    different cicuit maybe rob, but they all end at the h/u post breaker.
    i assume you mean the post breaker is tripping or do you mean the vans socket breaker ?
  5. pappajohn
    Aug 26, 2007
    29,946
    17,609
    YO11 2BD
    just a thought !
    on the vans fuse box.......if any of the teminals are loose on the MCB that can cause a false trip.
    it wont trip immediately but over time it can.
    if its accessible, REMOVE THE HOOKUP CABLE FIRST, then remove the cover on the fuse box and tighten all the breaker teminal screws.
  6. rob kinnear
    Nov 29, 2010
    175
    31
    Swansea
    Van circuit tripping not post I will check MCB on return home
    Rob
