Electric cable (1 Viewer)
Lookaround
59
19
Ireland
Van Conversion
Since 2004
I'm having trouble with the electric cable. When I'm plugging the cable into the Motorhome it is very difficult to get it in fully. Then when I'm disconnecting it it a is getting almost impossible to pull it out. If there anyway to make this any easier - could I put some oil on the outer edge of the van socket - avoiding the pins obviously.
Jul 13, 2008
3,737
3,818
Low profile
I think you will have a small clip/locking mechanism that holds it in place, mine has.
scotjimland
2,257
9,780
A Woosh bang
the pins on the plug and socket are probably corroded..
clean the pins with some emery cloth and lubricate with Vaseline or silicone grease or just tray a spray with WD40 or silicone
warning.... don't start until you have the supply plug out and beside you
Jul 29, 2013
9,067
18,426
Salisbury
Hymer B678DL A class
since 2011
Try a bit of silicone spray that would be safer than oil
Lookaround
Lookaround
59
19
Ireland
Van Conversion
Since 2004
#boringfrog When you mention about the clip/ locking mechanism do you mean the cover of the blue plug which fits over the socket or is there something else there that I'm missing. This hasn't always been a problem - it's always been a bit stiff but now it's got really tough in just the last month or so.
Regarding the silicone spray - an I spray directly on to the pins. Next question - where would I get silicone spray - motor factors?
scotjimland
2,257
9,780
A Woosh bang
yes.. spray the pins and the socket liberally .. then work the plug in and out ..
buy at Halfords
Badknee
7,407
412,097
notloB
Vantage Neo
Living the dream.
It would be better to strip the plug down and clean the pins up, make sure the electrical connections are made well with all the pulling and tugging you have had to do. You can get tiny bottle brush type wire brushes that are ideal for cleaning the socket part with. eBay or Halfrauds will have both the silicon spray and the wire brush.(y)
andy63
4,672
15,017
south shields
None
since 1990
There may be a small lever alongside the socket which needs lifting to allow full engagement. . And again to allow you to disconnect.. mine has that feature ..worth looking..
You could get silicone spray from a builders merchants / plumbers..
Ta andy
Khizzie
3,794
5,695
Le Repaire,Thiviers,France
Autocriuse stargazer
since 2002
Usually to the left of socket there is a small blue lever that you need to push down to release the plug and withdraw it..
denisejoe
5,616
12,042
Warden isle of sheppy
Since 2004
ours has a lever on the left that you hold down with your thumb to release the plug
joe
andy63
4,672
15,017
south shields
None
since 1990
Here you go... This is what I and others have mentioned.. It might be that causing difficulty.
scotjimland
2,257
9,780
A Woosh bang
done that myself... but sometimes it's cheaper and easier just to fit a new plug..
Feb 4, 2010
2,329
1,590
Mid. Glamorgan, S. Wales
Motorhutch / Toy Camper
Since 2010
I've got the same problem - a bit tight when plugging in and you're not 100% sure if it's fully engaged. Really difficult to pull out. The lever makes no difference. The pins in the socket look OK, but difficult to tell with the cables (10m & 25m). I'll have to try silicone spray or similar.
Dazzlin
1,751
6,213
La Marina, Costa Blanca.
1986 Hymer A Class
From 2013
I had same problem. We only use ehu a couple of times a year and I blamed lavk of use of the lad.
Silicone spray on the plastic cured it and won't harm the pins.
Made a world of difference.
Slides in and out beautifully now!
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
Some of these plugs can be really tight, I have the same ones on my workshop machines and I fell over pulling one out when it didn't come I pulled very hard and it gave, so did I straight back on my bum. The contacts are tight for a good current draw, I pull 32 amps on start up for the saw.
Mar 11, 2013
1,280
1,678
Gillingham
coachbuilt
since 2005
These BS 4343 blue plugs and skts are rated at 16 a so be careful drawing 32a.
Lookaround
Lookaround
59
19
Ireland
Van Conversion
Since 2004
The Silicone spray worked a treat. I have also used it on lots of squeaks in the house too. Thanks for the tip.
