Electric Blanket - Inverter (1 Viewer)
Brian_K
271
247
Durham
Coach Built
Would anyone have any experience of running an electric blanket through an inverter?
I’ve rang Dreamland and they say no, either with a modified or pure sine wave. Also rang Kampa, they simply didn’t know.
Any guidance appreciated.
Brian
funflair
19,342
30,216
Guisborough
MORELO palace
since 2012
As far as I am concerned a decent pure sine inverter is just the same as plugging into EHU, other than the available battery capacity issue.
I stand to be corrected by those in the know with electrickery.
I find sending the wife to Bed first works just as well.
Martin
funflair
19,342
30,216
Guisborough
MORELO palace
since 2012
Just looked at one Electric blanket spec and 140 watts on max so thats about 12 amps from your 12 volts, leave it on for 20 minutes to take the chill off and less than 5 ah gone, an hour or two of sun on a couple of panels in the morning and it could all be put back in before you are even out of bed.
Dont leave it on all night though.
Martin
Brian_K
Brian_K
271
247
Durham
Coach Built
Just find yourself a hot woman, or a warm one, who will do the job just as well, but not with quite the same level of enjoyment!!
Ha, had one for the best part of 40 years, just me and the mutt now and I ain't sleeping in a bed with him all night, he snores and is always chasing rabbits in his sleep :D
Brian
Nov 18, 2011
11,862
42,968
Planet Earth
A van
Over 25 year's
hot water bottle dos the job for me why put your battery's through all that stress motorhoming is camping if your a bit cold get a onesay
I like to save my battery's for more important things computer TV blown air hetting
Jan 22, 2013
1,253
60,200
London SE
A class Adria vision I707
since 1971
I brought a 12 volt blanket for the bed over the garage, usually plug it in about 20 mins before stopping for the night,
it warms up the bed nicely but I wouldn't use it without the motor running ,
the good thing now is the missus doesn't clamp her self to me like in the alien:LOL: sucking out all my body heat,
Steve
1,613
2,062
Compton Berkshire
C class
on and off for 40 years
if you have the power then use it, does batteries no harm at all to give them some work. i hit mine hard most days with the toaster or microwave they are now 3 years old with no sign of a problem. Why pay out all that money and not use it.
Feb 27, 2011
14,732
75,882
UK
Self Build
maz
Jan 26, 2011
4,460
7,740
Bizeljsko, Slovenia
N+B Arto
Since March 2011
Being a soft southerner, I have been running a 65w Dreamland electric blanket off a Sterling pure sine wave 200w inverter for over 4 years with no problems. It's the blanket controller that needs pure sine. Mine's a 'Turbo' model which heats the bed up quickly so I only need to run it for 15-20 mins. The solar panels easily replace what it's taken from the batteries.
Feb 27, 2011
14,732
75,882
UK
Self Build
Sheepskin rug for me. No power needed. In extreme cases I would dig out my hot water bottles. But haven't needed them since the first two very cold winters I was fulltiming.
Mar 26, 2009
8,162
11,221
Yr Wyddgrug
Hymer B678DL
Since 2009
Sheepskin......I love it when you talk dirty:LOL:
Minxy
32,649
66,534
E Yorks
Carthago Compactline
Why not go for a heated throw instead? I've got one and it's brilliant - I can use it at the front of the camper plugged into the inverter there to keep me snug whilst travelling or could put it on the bed instead - they are about 150w so not a massive draw. Below is an example of one:
Broken Link Removed
Brian_K
Brian_K
271
247
Durham
Coach Built
A 'simple' blanket (without any complex controls) will work off any sort of inverter.
That seems to be the trick from what I can understand. The Dreamland Inteliheat are to be avoided if using an inverter.
I decided to go for a Silentnight Essentials underblanket in the hope the electrics were simple and my 300w MSV inverter would run it OK. Find our tomorrow.
Brian
