Elddis Autostratus EK
Discussion in 'Motorhome Chat' started by goffer, Jul 5, 2011.
  1. goffer
    goffer Read Only Funster
    Mar 15, 2010
    77
    15
    weymouth sunny dorset
    Can any one help me please, I have an Elddis Autostratus EK 1999/2000 model. Where is the Leisure battery charger situated? or is it charged via the alternator, so what happens when on EHU? I have a solar panel but that is wired to a connection near the battery box. Any advise will be greatly appreciated,
    Tony:Blush:
  2. chrisgreen
    chrisgreen Funster
    Jul 26, 2009
    5,604
    7,313
    england
    mine is under the wardrobe floor behind the heater,not sure if yours is the same though?
    chris
  3. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    ^^^whs - switch to right of control panel, charger beneath wardrobe floor, to the left of the RCD Box - will be black.
    If you are having charging problems when running and on hook up, then look at the battery fuse - inboard under the side seat, near the battery box - and then check the battery.
    Put 'on charge' and run a meter across the battery terminals - have a stool close by, so you can pull the battery out and sit on it. Should be around 14v on charge.
    Could be that the battery is fubar'd and is not accepting charge.
