Elddis Autoquest 120, 12v problem
Discussion in 'Motorhome Chat' started by Dolomite Pete, Oct 13, 2013.
  1. Dolomite Pete
    Dolomite Pete Read Only Funster
    Oct 13, 2013
    23
    7
    Alton
    Hi,
    I've got a new (to me; 2007 model) Elddis Autoquest 120, and my entire 12v system has gone dead. I've checked that the isolation switch by the door is on and that the leisure battery is good. It's happened before and just came back on again. Does anyone no the location of the relay that the door switch operates?
    Has anyone had a similar problem?
    Any help appreciated.
  2. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,949
    There are several handbooks for download in the Elddis Archives. Wiring diagrams might have the information.
  3. Dolomite Pete
    Oct 13, 2013
    23
    7
    Alton
    Wiring Diagrams
    Thanks, but I do have a wiring diagram, which shows the relay, but not where it is in the van; I'll keep looking!
  4. tick59
    tick59 Funster
    Dec 25, 2007
    1,260
    1,115
    Newcastle Upon Tyne
    :Doh::Doh::Doh:
    WE HAVE HAD THIS PROBLEM BEFORE AND FOUND THE SWITCH FOR THE BATTERY IE VEHICLE/ AUXILLARY WAS STUCK IN THE MIDDLE AND NOT ON VEHICLE/ AUXILLARY. CHECK TO MAKE SURE IT IS SWITCHED TO ONE OR THE OTHER AND NOT IN THE MIDDLE.
  5. Rob e Lee
    Rob e Lee Funster
    Apr 16, 2012
    441
    555
    Surrey
    Do you have the 12v isolation switch inside habitation door? Ours burnt out - bridge or join connections at back of switch and see if it comes back on. We have an Elddis 180.
    Rob
  6. Ed Excel
    Ed Excel Funster
    Nov 27, 2012
    869
    577
    Ribble Valley
    I would suggest the relay should be near or in your 12V distribution panel. After all, the reasons for having a relay (group circuit switching, voltage drop) determine where the best place to locate it is.
  7. Dolomite Pete
    Oct 13, 2013
    23
    7
    Alton
    Cracked it !!!
    Many many thanks to tick59; you cracked it. It was the vehicle / aux switch stuck in the middle! Thank :thumb:you sooooooooo much mate.
    • Like it Like it x 1
  8. Rob e Lee
    Rob e Lee Funster
    Apr 16, 2012
    441
    555
    Surrey
    On our 180 the relay is in the same box as main fuses/mcb's located under rear seat. I found it very awkward to access. When our 12v system failed we were stopped at the top of a mountain in Ausrtria somewhere. I was outside admiring the view when my wife informed me that our pump was not working. On investigation it was discovered all 12v power had failed. Gave up trying to fault find and on the way down I asked my wife if she had checked door switch was in the 'on' position which it was. That's when I decided to check switch anyway just to be sure - turned out be an easy fix. Waited till we got home and changed switch for a better quality one - been fine since.
  9. GJH
    Aug 20, 2007
    27,349
    34,949
    I nearly suggested that but thought better of it when reading that it had cured itself previously :Doh::Laughing:
  10. tick59
    tick59 Funster
    Dec 25, 2007
    1,260
    1,115
    Newcastle Upon Tyne
    :Rofl1::Rofl1:
    WELL DONE SEE IT ONLY TAKES A DAFT GEORDIE TO SORT THE PROBLEMS OUT FOR FUNSTERS. GO ON HAVE SOME FUN!!FUN!!!FUN
  11. tick59
    tick59 Funster
    Dec 25, 2007
    1,260
    1,115
    Newcastle Upon Tyne
    :Rofl1::Rofl1::Rofl1:
    TO LATE GRAHAME THE DAFT GEORDIE GOT IT RIGHT FIRST GO.HA! HA!
  12. GJH
    Aug 20, 2007
    27,349
    34,949
    First time for everything Bill :Rofl1::Rofl1::Rofl1:
