Elddis 175 Slow Draining Sinks (1 Viewer)
Cliffy38
83
37
Harlow
Elddis 175 Prestige
since 2012
have noticed that both the kitchen and bathroom sinks have become slow draining. It is more noticeable if you have the drain tap open. First try was to clear the kitchen sink drain. I noticed a small hole towards the top of the tank which I assume is required to stop a vacuum. Pushed something through the hole and no resistance so assume it isn't blocked. Next attempt will be to remove all pipes to tank, flush them out and the tank. However any advice before I do this would be appreciated.
Feb 26, 2012
528
368
coach
Motorhome since 2006 (caravanning 38yrs)
Try putting toilet fluid down each followed by a little water and leave over night. I always pour fresh water down each when returning home from a trip to flush out any waste that may stick in the bends and low spots.
RS_rob
1,010
669
Turnford
over a Year Yay................
Have you tested it with the drain valves open ?
TheBig1
17,630
43,275
a bottle of cheap cola down each plughole helps clear any fatty deposits and stop the pipes smelling too
my initial thought was that the pressure relief vent is blocked on the tank, but you say you've checked already
