ehu (1 Viewer)
rickyd
18
Lincolnshire
low profile
Just bought our first motorhome. Dec 2010
Recently bought a Bessacarr e460 but due to weather have not been able to use it yet. I have left it hooked up with the ehu and a small electric heater on just to keep the chill off. Will this damage the battery. Is it ok to leave ehu on all the time during the cold spell?
old-mo
Extra Special
16,341
93,473
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
I leave mine hooked up all the time,, once the battery`s are charged, It is like an ordinary charger and slows the input charge down to next to nothing.
The best and safest heater`s are the small "Delongi" oil filled type. :thumb:
I am usually wrong,,, so expect some one else will contradict what I have said. :winky:::bigsmile:
rickyd
rickyd
18
Lincolnshire
low profile
Thanks. I am also using a small oil heater. My main conern was whether it was ok leaving it hooked up all the time, but seeing as you do it all the time with i am asuming no adverse effects, then I will carry onduring the cold weather.
DESCO
2,646
266
London
low profile
18 years +12 years tugging
Have done the same for years and have not had any problems.
Dave .:thumb::thumb:
2,316
1,989
West Yorkshire...Halifax
Vanless....BUT....!!!!
I did the same last year when it was rather cold.. plugged it in to the mains with the adapter and had a small halogen heater on inside just to keep off the chill and dropped all the water fresh and waste out of it...Well we were selling it and i didn't want any probs with it
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
must get some new glasses I thought this would be about Rod Hull:ROFLMAO:
oldun
747
162
St Neots
VW Campervan
Since 2001
Just to be awkward - why an oil filled heater?
I use a simple convection panel heater, these are lighter than an oil filled heater and respond much more quickly.
Mine has a solid element (like an immersion heater) so is also very robust.
4,086
5,902
SW Scotland
LP Coachbuilt
Since 2008 after caravanning for 20 years
I use a convector heater as well, just plugged it in after a trip away. A tip is to change the charge over to the chassis battery for 24 hrs once a week, that way she will always start when you turn the key.
Rgds
Bill
1,052
290
The universe
Rgds
Bill
Or get a battery master fitted,that way both batteries will always be charged:ROFLMAO:
1,052
290
The universe
Or just connect the two, for the same result but a lot less money!
However, if you are off EHU for a while, you WILL run down your Engine battery unless you run your engine for a while every day:Eeek:
43,207
48,821
convectors need to be on constantly whereas an oil filled rad will hold heat a lot longer when the thermostat kicks in and turns it off.
cheap and cheerful oil rads should be stood on a tin dinner tray incase of leaks....bugger getting hot oil out of a carpet !!!
Bailey58
8,785
29,146
Norfolk and Toftir.
Sold
July 2010 (ex tugger)
On a slight detour but I've left mine plugged in for the past month with an old oil filled rad on a minimum setting but I've noticed it doesn't get hot at the top as if it needs bleeding like a wet system in the house.
I've never bothered turning the stat up to see if it makes a difference but I wonder if the the clue is in the "old" ?
