Ehu usage in amps
Discussion in 'Motorhome Chat' started by flatpackchicken, Apr 12, 2013.
  1. flatpackchicken
    flatpackchicken Funster Life Member
    Jun 27, 2010
    926
    897
    BICESTER OXFORDSHIRE
    Just found this useful bit of info about EHU re wattage used and what amps are being used???
    Regards Garry Flatpackchicken
    Heres a chart to help you calculate your electrical items useage when using EHU.
    60 Watts = 0.26 Amp
    100 Watts = 0.43 Amp
    200 Watts = 0.87 Amp
    300 Watts = 1.30 Amp
    400 Watts = 1.74 Amp
    500 Watts = 2.17 Amp
    600 Watts = 2.61 Amp
    700 Watts = 3.04 Amp
    800 Watts = 3.48 Amp
    900 Watts = 3.91 Amp
    1000 Watts = 4.35 Amp
    1100 Watts = 4.78 Amp
    1200 Watts = 5.22 Amp
    1300 Watts = 5.65 Amp
    1400 Watts = 6.09 Amp
    1500 Watts = 6.52 Amp
    1600 Watts = 6.96 Amp
    1700 Watts = 7.39 Amp
    1800 Watts = 7.83 Amp
    1900 Watts = 8.26 Amp
    2000 Watts = 8.70 Amp
    2100 Watts = 9.13 Amp
    2200 Watts = 9.57 Amp
    2300 Watts = 10.00 Amp
    2400 Watts = 10.43 Amp
    2500 Watts = 10.87 Amp
    2600 Watts = 11.30 Amp
    2700 Watts = 11.74 Amp
    2800 Watts = 12.17 Amp
    2900 Watts = 12.61 Amp
    3000 Watts = 13.04 Amp
    3100 Watts = 13.48 Amp
    3200 Watts = 13.91 Amp
    3300 Watts = 14.35 Amp
    3400 Watts = 14.78 Amp
    3500 Watts = 15.22 Amp
    This article is meant as a general guide only. You must take professional advice when using or considering installing electricity in your tent, or caravan motorhome or RV.
    • Like Like x 8
  2. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,822
    3,326
    Eastbourne East Sussex
    While true, to convert watts to amps, just divide by 230 (the mains voltage) or if a 12v appliance, by 12.
    As a guide I find it easier to divide in my head by 250, so 1000w = 4amps (actually the correct figure is 4.34A) which is near enough for most purposes .:thumb:
    • Like Like x 2
  3. Gromett
    Gromett Funster
    Feb 27, 2011
    8,080
    14,662
    UK
    Whilst spec wise true, in reality divide by 240V in the UK :Wink:
    But I am the same as you and use 250 in rough and ready calcs.
  4. oldun
    oldun Read Only Funster
    Mar 23, 2008
    748
    160
    St Neots
    I thought that the whole of Europe was going to set (harmonise) voltages to 230V?
    The actual MH socket your MH socket may be lower due to the long site distrubution lines.
  5. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,907
    17,578
    YO11 2BD
    Correct....
    UK voltage is now 230v with a tolerance of +10% (253v) and -6% (216v)
    it was 240v before harmonisation.
    • Like Like x 1
  6. scotjimland
    Jul 25, 2007
    28,934
    25,601
    It already is harmonised, The UK is 230 V .. with a tolerance of +10%/−6%
    as an aside, I've been on Spanish sites and measured it as low as 220v ..
    but this is all academic .. for easy mental calculations, as Reallyretired said.. use the rule of thumb as 4 amps per kw and you won't go wrong..
    edit.. just beat me to it John :Laughing:
    • Like Like x 1
  7. Ed Excel
    Ed Excel Funster
    Nov 27, 2012
    869
    577
    Ribble Valley
    I think you'll find it's changed to +-10% if you look at BS EN 50160:2000 Voltage characteristics of electricity supplied by public distribution systems.
  8. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,116
    3,524
    walthamstow east london
    its all eu double speak as youll still get 240v 99% of the time in uk they set the limits to include virtually everyones existing voltage
    • Like Like x 1
  9. Gromett
    Gromett Funster
    Feb 27, 2011
    8,080
    14,662
    UK
    When the spec was harmonised they didn't rip out all the power stations, generators and substations and replace the 240V ones with 230V ones. Nothing changed. We are still on 240V. If you don't believe me put a multimeter into your power socket...
    Mine is currently reading 243v...
    All they did was a bureaucratic exercise as is typical of the EU.
    Uk is 240V, France is 230v so they chose a tolerance range that included both voltages.
    The voltage near a sub station tends to be higher to allow for voltage drops at the end of a long line. I have seen as high as 246v. I have seen as low as 235 on a campsite at the end of a long run.
  10. Ed Excel
    Ed Excel Funster
    Nov 27, 2012
    869
    577
    Ribble Valley
    The important point is, 230 is the nominal figure which manufacturers of electrical equipment should be working to, for goods to be used in the EU, with cognisance of tolerances. And, if you are thinking of purchasing something made outside the EU you may also find this info useful.
    • Like Like x 1
  11. Gromett
    Gromett Funster
    Feb 27, 2011
    8,080
    14,662
    UK
    We moved away from the important point after the first post in the thread :Wink::Rofl1: My responses about the actual voltage being 240v was in response to
    The true usage is gained by using actual values not by use the center spec value created by eurocrats. In the case of the UK the voltage is actually 240V. You will quite often see power supplies these days which tend to be switch mode having a much bigger voltage range than is needed. My laptop power supply works from 100v - 260v. So the supply is not designed around the eurocrat 230v spec at all.
    I prefer to either use the rough and ready 250v if it is for rough and ready purposes, OR I use accurate voltages if the calculation actually matters. In the case of the UK it is 240V.
    Anyway, we are into the fun pedantic territory now.
    PS: Not having a dig at reallyretired here.
  12. olley
    olley Funster
    Jul 29, 2007
    3,763
    2,273
    Ipswich
    You bunch of pedants :Rofl1: I have always used 250v, and 10amps at 12v for 100watts of inverter power, both plenty good enough for basic wiring, why make life complicated.:BigGrin:
    Ian
    • Like Like x 2
  13. motorhomer
    motorhomer Read Only Funster
    May 17, 2008
    578
    317
    South Shropshire
    This is all academic! The voltage that matters is the ACTUAL voltage on a site and - especially on some remoter sites on the continent - this can be miles away from the theoretical figure and will vary according to load at the site.
    My fridge has auto power source selection, and it uses mains in preference but switches to gas if the mains voltage drops below 190. in the UK it always selects mains. In Spain sometimes it does but sometimes it doesn't. Recently got back from morocco and it hardly ever worked on mains there (at least when left on Auto, you can over-ride it). Sometimes the fridge will be working on mains but then switch to gas if I switch on the electric boiler, whose load causes the voltage to drop (but again not in the UK where 240v and 16amp are pretty reliable)
  14. keith
    keith Funster
    Aug 25, 2007
    3,285
    1,671
    Ecclefechan
  15. scotjimland
    Jul 25, 2007
    28,934
    25,601
    put a complaint into the Management .. tell JJ to buy a Honda :Laughing:
