EHU to home/garage
Discussion in 'Motorhome Chat' started by camel, Feb 7, 2012.
  1. camel
    camel Funster
    Apr 25, 2010
    32
    4
    Durham
    Hi, Is it ok to connect our motorhome to a socket in the garage to keep the batteries topped up - can it be left for days at a time or should it be disconnected after so long?
    Also, could I leave the heating on, on a low setting on the thermostat, to reduce the chance of freezing pipes or would it be better with a small oil filled radiator or similar? Thanks, Paul
  2. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,912
    23,657
    Narrfoook
    Hi Camel, yes you can leave it plugged in for as long as you like without issue..
    A small oil filled radiator is a good safe option too
  3. Phill D
    Phill D Read Only Funster
    Dec 6, 2011
    4,414
    4,633
    South Wales
    i agree with Jaws as i do it all the time. have stopped using the small oil filled rad since a recent post where one caught fire!
  4. wasp
    wasp Funster
    Dec 21, 2008
    2,733
    1,072
    Mansfield
    Hi Camel I leave mine on hook up permanently and leave the van heater on I am not a lover of oil filled radiators I leave the stat set for 15/20 degrees that keeps it nicely aired and doesnt freeze up:thumb::thumb::thumb::thumb:
  5. Jaws
    Sep 26, 2008
    18,912
    23,657
    Narrfoook
    Oohhh No nice that.. I have been looking hard at the things recently too.. In the safety manuals that get passed around they are always top of the list.. Just goes to show !
    Mind you, there is the other side of the coin..
    Lord knows how many million oil filled rads are out there and it is def not that common for them to catch fire.. So far just your one Phil ( and how unlucky can you get !! )
    And you can bet there are a lot more fires caused by fan heaters or those ruddy halogen light things..
    Oh, just a thought but a couple of those nice little green house electric tube heaters might be handy.. Low wattage and you could put one each end of the van
  6. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,320
    8,028
    West Norfolk
    15/20 degrees!!!!:Eeek:
    Let us know who your leccy supplier is so we can afford to leave it that high too!!!!!:Laughing:
    We have ours set at about 10 degrees, just enough to keep any fabrics from feeling cold.:thumb:
    We have our charger on to provide a maintenance charge to the batteries too.
  7. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,975
    14,092
    Norfolk
    Agree with the above but depending on your setup, the domestic batteries will be ok but the starting battery may not be maintained if there is no link.
    We use an oil filled rad , all cupboards open and one vent slightly open. All cosy and dry .
  8. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,950
    On our Autoquest (before I fitted a Battery Master) I used to keep the starter battery topped up when I had the van on EHU by using a Tronic T4X charger plugged into one of the van 240 sockets.
