EHU polarity (1 Viewer)
S
sinbad1
Was thinking of buying one of < Link Removed >;but having read several posts regarding the safety of these inline units and looking at the cross over switch, to me looks a bit flimsy. I have changed my mind and gone for the cheaper option of connecting up a male and female where + and - are reversed.
Had a few old connecters lying about so thought i'd make up a compact unit the bit between the male ond female is b&q 50mm pipe fits like a glove.(glued with pipe cement)
Link Removed
43,329
49,442
Wow!!!! someone with a little gumption.:winky:
one of the best diy jobs i'v seen for a long time.
i have the same type lead i made but never thought of the tube idea. :thumb:
S
sinbad1
Thanks John don't suppose i'll use it here ( you never know?) did think of adding a red neon on the tube ;but have a red indicater on my PSU unit.
Losos
549
4
Suffolk & Czechland
Looking to buyi
N/a
Yes, that's really neat and using the 50mm pipe makes it both safe and compact, I must start making notes on things like this since I expect to be a regular EU / UK traveler.
oldun
747
162
St Neots
VW Campervan
Since 2001
The tube idea could only be used with a in-line connector lying on the ground or on some other type of support. I do not like the idea of leaving unprotected cable connectors lying on the ground.
It could not be directly plugged into a socket due to the large forces exerted by the long stiff unit.
I use two blue connector (one male and one female) connected by a short length of cable. This can be plugged into the MH and the normal EHU daisy chained on the end. This still leaves the connector out in the open and thus accessible by other campers and the weather but it is off the ground.
S
sinbad1
Not sure what large forces your talking about, fits fine no problem directly into the supply source, It would be pointless to use it as an inline connecter may as well have made up a crossover patch lead, the idea was to eliminate that, for me it works fine the whole unit weighs less than the male female with crossover cable, and less chance of water ingress.
Personally i prefere a long stiff unit, rather than a limp one:ROFLMAO::ROFLMAO:
oldun
747
162
St Neots
VW Campervan
Since 2001
Personally i prefer a long stiff unit, rather than a limp one:ROFLMAO::ROFLMAO:
The "forces" I was referring to is that of leverage (not really a force but a turning moment). A plug that sticks a relatively long way out of a socket will produce a large leverage or "moment" at the socket whereas a "limp" cable type will not. The force will be a downwards force but there will be little or no moment.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
You are quite right, IMHO, I nearly posted the same message. Sick it in the MH and you's knock it off in 10 mins, stick it in the pedestal and the first person who trips over the cable wrecks the pedestal connector and try explaining that in a foreign language.
Mine is a pair of connectors and a short wire, can be used at either end.
S
sinbad1
Most supplies are either downward facing or at 45 degrees , so the moments of the limp and stiff will be somewhat negligable
As previously said the mass of my unit is less than the limp method so if you put this into your equation then i don't really think there would be a great deal of difference.
I would agree that any unatural forces to the fixed plug would result in an increased leverage ;but think this is unlikely.
Unless you leave a site whithout unplugging:Eeek:
Regards
scotjimland
2,324
10,040
A Woosh bang
Mine is even simpler.. I don't use any .. :winky:
but let's not get into that again.. each to their own and it's not worth another ten pages on Jim's server :Doh:
Sorry Sinbad1., it's a neat job but can't see any great benefit .. if it works why fix it ?
S
sinbad1
Not really a fix Jim, needed to make up a crossover cable so designed a simple more compact unit.::bigsmile:
No i won't ask the question:winky:
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
They said the same about the Inclinometer, and Olley summed it up in one:thumb:
These folkes have no Panash no Va Va voom:Doh:
Left to these we would still be living in caves:ROFLMAO::ROFLMAO:
scotjimland
2,324
10,040
A Woosh bang
Geo ... The Gadget Man :ROFLMAO::ROFLMAO::ROFLMAO:
Link Removed
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
:ROFLMAO::ROFLMAO:You've got me bang to rights Jim:ROFLMAO::ROFLMAO:
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Mine is even simpler.. I don't use any .. :winky:?
It's people like you that US money. The government spends millions on adverts for responsible coupling just because people like you could not care less and die in your thousands.
Couple Responsibly, always take precautions.
scotjimland
2,324
10,040
A Woosh bang
Just getting a coupling is an achievement in itself .. why make an easy job hard :Doh::roflmto:
S
sinbad1
I agree, there's allways going to be the odd cave dweller::bigsmile: I welcome any constructive criticism, for me it a safe and compact unit does what i want and takes up less space than two connecters.
Now complete
Link Removed
Regards
PM me if you need instructions
JayDee
1,057
169
N. Devon
7 Years after 5 years with caravan.
Regards
Nearly saw that a coupla weeks ago. It's only when the driver saw me looking at his hook-up lead that he rememberd, went :Blush: and thanked me most profusely - well we've all done things like that, haven't we? (I remember coming off ramps with my Fiamma still wound out:Doh::Doh:). Could have done a bit of damage to his MH, to say nothing of the power tower.
John
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Now complete
Link Removed
Regards
Well spun Sir.
Now re-take that picture with a plug in the end of the cross-over and see how it looks :)
OK, I admit it looks top quality and it's not *that* long.
S
sinbad1
John
To be honest no i've not done anyrthing like that(famous last words :Doh:) ;however, it probably would cause damage to MH and or post, irrespective of what connecter was fitted.
Narrow escape then with the fiamma:Eeek:
