EHU on the continent - a bit of help, please
Discussion in 'The Beginner' started by Kensmith314, May 27, 2016.
  1. Kensmith314
    Kensmith314 Read Only Funster
    Mar 18, 2015
    40
    51
    Shropshire
    In a couple of weeks I will be travelling in France, Belgium, Luxembourg, Switzerland and Italy.
    We will mainly stay on ACSI sites with EHU.
    Can anyone tell me, please, will my standard cable be OK or do I need to take some kind of adpator to fit into the electric posts>
    Thanks.
  2. Scrappie
    Scrappie Read Only Funster
    Aug 6, 2015
    47
    61
    France
    Yes it's fine, Euro wide.
    Have a great trip!
  3. Smith and Sharp
    Smith and Sharp Funster
    May 31, 2015
    1,347
    2,263
    Cornwall
    You may want to get one of these... Less than a fiver....(y)
  4. wingman
    wingman Funster
    Feb 10, 2013
    985
    2,490
    Romford, Essex
    Take the adaptor that @Sas r us has posted above. Many sites have the 'standard' adaptor, but some sites still use that 2-pin plug. Certainly, I had to use the 2-pin In France and Switzerland recently.
    The site will probably loan you one, but best have your own in case.
  5. Scrappie
    Aug 6, 2015
    47
    61
    France
    That's good to know for us too, we have never come across it but will get one for Justin.
  6. Treeeev
    Treeeev Funster
    Nov 9, 2015
    71
    49
    Shenfield
    Most of the sites these days have the "standard" 16A sockets, but there are a few sites using the 2 pin continental adapter. As Sas r us & Wingman have said, get yourself an adapter. You may not use it this time, but you will use it sometime
    Trevor
  7. mikebeaches
    mikebeaches Funster
    Feb 22, 2010
    1,036
    686
    Bristol
  8. Smith and Sharp
    May 31, 2015
    1,347
    2,263
    Cornwall
    Any camping shop should sell them....
  9. Speve
    Speve Funster
    Jul 29, 2013
    2,043
    1,769
    Salisbury
    You also need to bear in mind that some supplies have reverse polarity it's a good idea to have a couple of leads made up for that just in case.
    You can buy the standard ones and change them yourself quite easily.
    • Like Like x 1
  10. Kensmith314
    Mar 18, 2015
    40
    51
    Shropshire
    Thanks for all of the replies.
    I will definitely get the adapter.
    In fact, I'll do it right now.
  11. Kensmith314
    Mar 18, 2015
    40
    51
    Shropshire
    And it's done . . .
    £5.85 from Amazon because I don't have Paypal for eBay.
    Thanks for all the help.
    • Like Like x 1
  12. Hettie's Crew
    Hettie's Crew Funster
    Sep 28, 2015
    110
    75
    Kingston upon Hull
    We had to use the 2 pin adapter at a couple of places around the Somme last year. Older, a bit run down sites. The big sites all seem to be the Euro plug.
    Also had to swap polarity a couple of times. On my previous van (Swift) a red light showed on the Sargent box if the polarity was crossed. This one (Hymer) doesn't appear to have that.
    Dead easy to swap polarity at the van end plug, if needed/necessary.
    • Like Like x 1
  13. NickNic
    NickNic Funster Life Member
    Jan 14, 2014
    5,591
    11,491
    Kettering
    I've got the 2 pin adapter somewhere. Never been out of the van.
  14. gus-lopez
    gus-lopez Funster
    Aug 18, 2014
    4,779
    8,969
    Lorca,Murcia,Spain
    Use mine all the time at home.:)
  15. laneside
    laneside Funster
    Aug 14, 2009
    3,536
    5,490
    Oradour sur Vayres
    Regardless of information posted lots of French sites still have the two pin plugs, no worries now you have one though
  16. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,706
    17,323
    YO11 2BD
    I made a reversed polarity lead when I first started motorhoming.
    Never used it as there's no point
    Throughout Europe only us Brits worry about it.
    No earth on some campsite hook up bollards, UK and European, is far more dangerous.
    • Like Like x 1
  17. namwaldog
    namwaldog Funster
    Jan 2, 2015
    439
    738
    Cumbria
    I don't have our ACSI books with us tonight but I seem to remember that there is a symbol in the guide to indicate the type of electrical connection at each site. Is it something like 'CEE' or similar?
  18. Tweedie
    Tweedie Funster
    Sep 14, 2015
    182
    137
    Northants
    So far we have had to use the adapter on nearly all the ACSI sites in France and Spain in fact we are using now on the ACSI site in San Sebastian which also has reverse polarity, although we don't have a lead for that but everything works OK.
  19. TheCaller
    TheCaller Funster
    Sep 23, 2013
    1,875
    2,245
    Lincs
    I expect that is because the Hymer will have been wired in such a way that polarity is not an issue. All double pole switches.
  20. autorouter
    autorouter Funster
    Apr 27, 2016
    123
    48
    Manchester
    The majority of sites have the standard blue socket, but by no means all of them.
    Yes, definitely get a continental adaptor, which will fit both French sockets (protruding earth pin) and German sockets (two metal slide contacts). That will do everywhere, including Spain and Netherlands, except Switzerland and Italy.
    In Switzerland the local domestic socket is three round pins in a shallow triangle. In Italy it's three round pins in a line. You can easily buy locally, or even borrow, adaptors to fit your continental adaptor. All the sites I've ever seen in Switzerland have the standard blue sockets. In Italy sites with local domestic sockets are quite common, especially off the beaten track.
