EHU Hookup convertor for France (1 Viewer)
C
Chockswahay
Crikey, I was just reading another French thread and the convertor was mentioned.
I had not given this a single thought (probably because we wild camp in Scotland lol)
I have also read that polarity is often reversed :Eeek:
Does any one have any advice re what type to buy please?
Many thanks :Smile:
stcyr
1,765
1,160
Normandie
On & off, since 1966 - fulltime since 2005
For sale in most French supermarkets - standard plug one end - hookup socket the other, blue. :thumb:
Heyupluv
3,862
1,593
France,
touring many years..42+
Many thanks :Smile:
Link Removed
with these two 16amp plug & socket above.. put a short piece of 16 amp cable in between and reverse the polarity at one end (meaning at one end put the brown to neg -..and the blue to pos + that will reverse any electric that is reversed back to normal....use the red tester below to check for reversed polarity and for NO earth...use the tester with the 13 amp trailing socket with the blue 16amp with a 13amp traling socket on one end
tonka
10,829
21,525
Cannock, Staffs
A class Burstner 800
Since 2000
Adaptor lead. Camping shops or ebay. Loads of them about..
You can buy or make a short swop over lead to deal with reverse polarity, some of us I know dont bother... The reverse polarity thing can start a whole debate and the Health and safety mob will come running. :ROFLMAO::ROFLMAO:
callumwa
4,110
4,480
Tyne & Wear, sometimes..
4 yrs +, 30+ yrs motorbike touring
Continental Adaptor here...
Link Removed
Reverse polarity tester here...
Link Removed
Reverse Polarity Adaptor...
Link Removed
::bigsmile:
and don't forget your Anti-Gassing Alarm Defence System...:RollEyes::RollEyes::winky::winky:....................
smiffy502000
249
124
sutton coldfield
coach built.
since 2008
hi. got mine on ebay. just typed in hook up cable continental, you will see lots come up got mine with a polarity test plug included, not very expensive:Smile:
ukbill
5,501
5,274
Pinoso
4 berth low profile
starting on saturday 10/3/2012
just make ya own get the cable and the plugs and reverse 1 end
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
To be honest whatever you need it is invaribly listed on my website with Funsters discount, all you have to do is :Eeek: and let your fingers do the walking:ROFLMAO::ROFLMAO:
For instance search 'continental' and hey presto a drop down box appears with a selection
Have Fun
Peter
May 21, 2008
4,271
7,340
Oxford
WildAx Constellation
Since 2008
Many thanks :Smile:
We didn't need to use ours recently in Alsace, the Vosges and the Haut Jura, nor in Germany, all were the same connections as UK.
Catherine
Jan 28, 2008
10,116
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
if you have switches with leds in them they will still glow even when switched of if you have revesed polarity
Spottycatz
452
487
Racodorm
Coachbuilt Low Profile
Still making mistakes! But they're not as costly.
So I plug the polarity tester in the French EHU and it shows me that the polarity is in reverse. :Sad: What do I do then? :Doh: Go to another site and hope the polarity is the same as my van, or do I ask the nice French camp person to come and do the electrical stuff on the EHU for me?
Dec 6, 2011
11,589
25,417
South Wales
Coach built Adria
you plug in your reverse polarity mini lead:Doh: then your normal ehu cable to van:thumb:
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
This is a good one but sometimes the mounting rail for the sockets is too far back or bodged and the angled wont cut it.
Techno
Jul 28, 2010
15,475
20,756
May 2010
IGNORE reverse polarity. Anywhere you hook up here or abroad you should check that your RCD/RCBO operates by its test button. If it trips you are OK. Don't buy unnecessary rubbish.
ukbill
5,501
5,274
Pinoso
4 berth low profile
its not alwayss rubbish my tv which is 12v cost about 90 quid started to play up when on rev pole so best to right the pole in case
Techno
Jul 28, 2010
15,475
20,756
May 2010
Reverse polarity cannot possibly cause a problem to a 12 volt TV nor a 230 volt TV
Reversing the polarity simply means that your switches will be in the neutral conductor instead of the line conductor. Your equipment does not know one from the other.
Unless you are going to take your electrics to pieces while it is LIVE polarity is irrelevant
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
Techno
Jul 28, 2010
15,475
20,756
May 2010
true but post FREE Peter and a STRAIGHT euro plug
ukbill
5,501
5,274
Pinoso
4 berth low profile
well my tv did have problems and as soon as i sorted the rev pole it was ok so as far as im concerned the tv was affected i have never had the problem before and nor after i always check for rev pole now i have a martindale permanently plugged in to check the pole's
Techno
Jul 28, 2010
15,475
20,756
May 2010
Pure coincidence
The device that converts 230 volts AC to 12 volts DC for your TV has absolutely no knowledge of polarity and works exactly the same either way around.
Likewise if it is directly connected to your battery , this is isolated from the mains by your battery charger.
ukbill
5,501
5,274
Pinoso
4 berth low profile
i dont believe in coincidence
ukbill
5,501
5,274
Pinoso
4 berth low profile
it seems a leci has already answered all i know is that a proper tv for a mh has a gadget in it that would stop any prob with a rev pole where as mine which is a 12v from comet at a fraction of the cost does not have that gadget or was i ill informed ?
and like i said it never happened before or after both rev pole was in czech and poland ?
Jaws
23,836
72,471
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
AC voltage
By its nature 50% of the time one side is -ve to the datum line, 50% of the time one side is +ve
As already said, the big difference is the feed line is usually switched rather than the return.. But that really is the only ACTUAL difference..
See below and you get the idea :thumb:
Techno
Jul 28, 2010
15,475
20,756
May 2010
The cheap TVs are/were a voltage stabilisation issue but I think you'll find that they are all stabilised these days at any price.
Spottycatz
452
487
Racodorm
AC voltage
:Eeek::ROFLMAO::Blush: I hated school!
