EHU & Charging
Discussion in 'Motorhome Chat' started by Glynn, Jan 7, 2012.
  1. Glynn
    Glynn Read Only Funster
    May 2, 2010
    163
    18
    Lancashire
    Is the van/engine battery also charged when on EHU on an Autotrail Cheyenne ?.
  2. hilldweller
    Dec 5, 2008
    27,250
    26,251
    Macclesfield
    Form your own opinion, it's the only sure way. Hook up. Wait an hour. Measure battery voltage ( any battery ), if it's 13V or over it's being charged.
    If anyone says "yes it is" then they are failing to say "yes it should be if your vehicle is working to specification". Same if they say "No" because if you have not owned it from new someone may have fitted a cross charging circuit.
    Voltmeter - £5 tp £10. Worth every penny.
  3. mike mcglynn
    mike mcglynn Funster Life Member
    Jan 6, 2008
    1,414
    5,698
    St. Helens MERSEYSIDE
    ehu
    Hi, my charger charges up the van battery if you press the controller pad symbol, Ive got a cheyenne 635, on my pad its the second from the left on the top row :Smile:
  4. Glynn
    May 2, 2010
    163
    18
    Lancashire
    Thanks for the reply's, what I meant to ask then was is it "supposed " to charge it ?.
  5. stagman
    stagman Deleted User
    Yes it is supposed to charge your lesuire and cab battery but only one at a time you need to select cab battery on your controler above the door to switch over to cab :thumb:
    • Like Like x 1
  6. robnchris
    robnchris Funster
    Jan 11, 2010
    1,350
    1,670
    Chester
    Battery Master
    If you want to charge both and not worry about having to switch them manually then get yourself a Van Bitz Battery Master, I have just fitted one to our Autotrail Arapaho with a Fiat ducato, the engine battery would only last 4 to 6 weeks when parked up and not being charged.
    We have a solar panel so hopefully this will now keep the engine battery topped up.
    If when ordering tell them you are a funster and you get 15% discount, happy days. :thumb:
    • Like Like x 1
  7. Glynn
    May 2, 2010
    163
    18
    Lancashire
    Sound interesting, do you leave the split charge relay in place with the vanbitz batt master ?.
  8. robnchris
    robnchris Funster
    Jan 11, 2010
    1,350
    1,670
    Chester
    van bitz
    There is an excellent info source on here about the battery master just type battery master into the search engine.
