egr valve blanking plate
Discussion in 'Motorhome Chat' started by Scattycat, Jul 8, 2016.
  1. Scattycat
    Scattycat Funster
    Jan 3, 2013
    843
    1,183
    Mayenne, France
    Just had the egr valve taken apart and cleaned and the mechanic suggested fitting a blanking plate.
    There are 2 types, one with a small hole in the centre and one solid.
    Which do folks think would be the best to fit?
    and if the solid one is fitted will the engine management light stay on and how does that affect the m.o.t.?
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,936
    17,600
    YO11 2BD
    Any lit dash warning lights which should normally be unlit will fail the MOT
    • Like Like x 1
  3. MH 55 FUN
    MH 55 FUN Funster
    Feb 18, 2016
    2,131
    3,285
    Rural South West Wales.
    Fitting a blanking plate with a hole in it is a pointless exercise as far as preventing recirculated exhaust gases / carbon entering your inlet manifold is concerned.
    Fitting a solid blanking plate may or may not illuminate the E.M.L. - depending on the engine & emission control level.
    I believe @Techno fitted a kit which prevents illumination of the E.M.L.
    • Like Like x 2
  4. Dorwyn
    Dorwyn Funster
    Aug 19, 2013
    586
    315
    somerset
    Sending the exhaust gases around for a second or more go has always seemed to me to be a dubious concept. But I am not an engineer, in fact nothing like an engineer.
    • Like Like x 1
  5. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,400
    2,666
    Surrey
    The concept is that any unburnt fuel gets burnt on the second pass, engines are massively inefficient, and do pass unburnt fuel down the exhaust. I had a 1980 Renault 18 and that had a similar system (that failed regularly). It makes the engine cleaner, producing lower emissions.
    I have read many of these threads and I have always wondered why you would bypass the EGR, they are fairly easy to replace, so if you get a light on the dash, replace the EGR? Is that not simpler?
  6. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,569
    3,376
    Telford, Shropshire
    Not entirely correct, the concept is that returning burnt combustion products into the combustion chamber lowers combustion temperatures thereby reducing the production of Nitrogen Oxides which have been proved to be harmful to humans when inhaled.
    D.
    • Like Like x 2
    • Informative Informative x 2
  7. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,400
    2,666
    Surrey
    Yes, that! :D
    • Like Like x 1
  8. Dorwyn
    Dorwyn Funster
    Aug 19, 2013
    586
    315
    somerset
    Still think it odd that using dirty exhaust fumes in preference to clean air is a good idea. The fact that it works in practice makes it more so. But thanks for clarifying the concept.
