Eggs and Skiing!
Discussion in 'Cooking in your Motorhome' started by jonandshell, Jan 30, 2012.
  1. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,318
    8,026
    West Norfolk
    We like our boiled eggs with a runny yoke, just starting to harden around the edges.
    Water boils at approx 92 degrees C at an altitude of 2300m above sea level.
    We have dippy eggs planned for breakfast one morning at Val Thorens during the forthcoming MHF ski meet!
    Does anyone know how long we should boil them for at 2300m altitude to attain the correct results?:Smile:
    Or should we give up and have a FB pie for breakfast instead?!
    • Like it Like it x 1
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,258
    17,927
    YO11 2BD
    8% longer than sea level for the same results
  3. Popeye
    Popeye Funster
    Sep 5, 2011
    7,995
    18,321
    New Forest
    At that altitude I calculate about 3/4 of an hour just to be on the safe side, then take your teeth out and gum it to death.......to avoid chipped teeth........:thumb:
    • Like it Like it x 4
  4. bigfoot
    bigfoot Funster
    Dec 23, 2007
    4,015
    5,342
    Wirral
    Heston says
    1.
    Place the eggs in the smallest pan available and only add enough cold water to cover them. Put the lid on the pan and place over the highest heat possible.
    2.
    When the water comes to the boil, remove the pan from the heat and wait for 6 minutes.
    3.
    After the time has elapsed, remove the lid and carefully remove each egg. Cut the top of each egg before serving in egg cups.
  5. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,318
    8,026
    West Norfolk
    I'll print this advice off and put it somewhere safe for the next 20 years!!!!:Rofl1:
  6. chrisboyo
    chrisboyo
    Aug 5, 2009
    1,338
    825
    Newport South Wales
    FB Pies for brecci ?
    Are you nuts ?
    Just think what could happen inside your one piece ski suit !!!:Rofl1:
    • Like it Like it x 2
  7. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,318
    8,026
    West Norfolk
    We never knew Charlton Heston was an egg connoisseur! Did he boil his eggs between takes during the Ben Hur chariot race?:Laughing:
  8. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,318
    8,026
    West Norfolk
    Here's something we bet that Charlton Heston didn't know-
    Here are other values for the boiling point of water a various barometric pressures and the approximate altitudes that corresponds to under normal conditions.
    31 in. Hg: 214 °F or 101.1 °C (at approx -1000 ft or -305 m below sea level)
    30 in. Hg: 212.15 °F or 100 °C (at approx sea level)
    29 in. Hg: 210.3 °F or 99.06 °C (at approx 1000 ft or 305 m above sea level)
    28 in. Hg: 208.44 °F or 98.02 °C (at approx 2000 ft or 610 m above sea level)
    27 in. Hg: 206.59 °F or 96.99 °C (at approx 3000 ft or 914 m above sea level)
    25 in. Hg: 202.89 °F or 94.94 °C (at approx 5000 ft or 1524 m above sea level)
    23 in. Hg: 199.19 °F or 92.88 °C (at approx 7000 ft or 2134 m above sea level)
    21 in. Hg: 195.48 °F or 90.82 °C (at approx 10,000 ft or 3048 m bove sea level)
    19 in. Hg: 191.78 °F or 88.77 °C (at approx 12,000 ft or 3658 m above sea level)
    17 in. Hg: 188.07 °F or 86.71 °C (at approx 15,000 ft or 4572 m above sea level)
    10 in. Hg: 175.11 °F or 79.51 °C (at approx 27,000 ft or 8230 m above sea level)
    5 in. Hg: 165.85 °F or 74.36 °C (at approx 42,000 ft 12,802 m above sea level
    Here in Norfolk, water boils at 101 degrees C !:Smile:
  9. Forestboy
    Forestboy Funster Life Member
    Jul 31, 2007
    5,130
    8,355
    Forest of Dean
    We gave up on boiled eggs at altitude years ago, stick to porridge when skiing nowadays keeps me going still spag bol at lunchtime :BigGrin::thumb:
  10. callumwa
    callumwa Read Only Funster
    Jan 16, 2011
    4,113
    4,518
    Tyne & Wear, sometimes..
    Yes, Many times, it was very very hot in the ampitheatre you know......:RollEyes:
    p.s. Do you put any salt into the water you boil your eggs in, as this will also affect the boiling temp.
    Sea (salt) water (1.025) boils at 103.7 deg C so better factor that in as well :RollEyes:....
    or
    How about croissants and coffee..........:thumb:
    Callum
  11. sedge
    sedge Funster
    Jul 7, 2009
    4,633
    4,193
    Nr Jct 3 M6
    My physics teacher told us that was why they were so keen to get back from climbing Everest (in 1953 I mean) - was cos they couldn't get a decent cup of tea, he said.
    Although knowing this was utter bollards, even when I was 11, this actually has enabled me to remember for 50 years so far, that water boils at a lower temperature the higher you go!
  12. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,318
    8,026
    West Norfolk
    mmmm, that could mean, we could offset the altitude by adding loads of salt to the water, thus adjusting the cooking time to be closer to that required at sea level!
    Also, an added bonus is that we could then sling the hot salty water down the sink and it will give the slide valve on the grey tank a good defrost!:thumb:
    Good advice!:Smile:
  13. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,070
    DERBYSHIRE
    you are boiling eggs not going into outer space with all this technical stuff:Rofl1:
  14. Terry
    Terry Funster
    Dec 27, 2007
    10,788
    6,294
    South yorks
    Buy a plastic egg thingy from either pound shop or Lakeland--it looks like a red half an egg that has markings on to tell soft med or hard --nether fails :thumb:You can use in cold or boiling water so long as the eggs and timmer thing are put in at same time = perfect eggs:thumb:
    BELOW one off ebay best £1.40 you will spend for a perfect egg :thumb::thumb::thumb::Wink:
    terry
    http://www.ebay.co.uk/itm/COLOUR-CH...pt=UK_Kitchen_Accessories&hash=item43aba6a8c5
    http://www.ebay.co.uk/itm/INGENIOUS...pt=UK_Kitchen_Accessories&hash=item256b8f53fc
    http://www.ebay.co.uk/itm/EGG-TIMER...pt=UK_Kitchen_Accessories&hash=item3f0f11cf86
  15. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,318
    8,026
    West Norfolk
    Cheers Terry!
    Timer thingy in the post and on its way.........................:thumb:
  16. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,318
    8,026
    West Norfolk
  17. pappajohn
    Aug 26, 2007
    30,258
    17,927
    YO11 2BD
  18. kelpbeds
    kelpbeds Read Only Funster
    Sep 16, 2011
    101
    13
    shrewsbury
    Nah, you're missing the best way Jon, you just blu tack it to your skis and then go so fast that the heat caused by the friction with ski and snow cook it perfectly!
  19. Terry
    Terry Funster
    Dec 27, 2007
    10,788
    6,294
    South yorks
    Thanks for the update--Glad you managed to get perfect eggs :BigGrin::thumb: They work even if you put them in cold water and bring to boil or straight into boiling water :Smile:
    I picked two up on Tuesday from Tickerty boos at Cleethorpes for £1 each after a day out with grandson :thumb: already given one away to some other poor egg-bound sole :Rofl1:
    terry
  20. ShiftZZ
    ShiftZZ Funster Life Member
    Feb 19, 2008
    19,812
    36,096
    Leicestershire
    And how exactly do you think they were made in the 1st place?
