EFoy
Discussion in 'Solar Power' started by jhbgaiem, Nov 21, 2008.
  1. jhbgaiem
    jhbgaiem Read Only Funster
    Jan 28, 2008
    59
    Galapagar near Madrid, Spain
    Does anyone here use Efoy batteries as an alternative to solar panels?
    They are very expensive but they seem to be one solution for getting more power without using a generator.
  2. scotjimland
    Jul 25, 2007
    28,936
    25,589
    This is the Power on the move - Efoy 1200 fuel cell for year-round power for medium and large motorhomes you refer to.
    Until prices drop I wouldn't consider it, for the half the money you could have a large solar array.. with no running costs. There is also the problem of sourcing and storing methanol .
  3. Tandy
    Tandy Funster
    Jan 13, 2008
    73
    14
    Cardiff
    Thanks for the link Jim. Is the web site owner a funster?:Smile:
    I too have been looking at supplementing our power supply.
    I am hoping to go skiing in our RV and I'm worried about keeping warm as I have no idea what sort of hook up (if any) will be available.
    I'm also unsure if we will be able to use the slideouts as that is bound to really let out the heat.:thumbdown:
    We have an oil filled radiator (which I leave plugged in when at home if a frost is predicted ,I'm not sure of it's electrical needs) and the RV is fitted with a thermostatically controlled "furnace" which i believe draws its power from the LPG tank.
    Any thoughts?:BigGrin:
    Andy
  4. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,690
    5,843
    Mansfield,Notts
    Taking one thing at a time and apologising if I'm teaching you to suck eggs
    You should be concerned about power reserves, although as you say your heating is run on gas, RVs are blown air and the fan eats battery's, no power =no fan=heating shut down, it wont run without the fan blowing
    Having the slide in or out makes a little difference but not a lot, the heating can cope when its running with the larger area, of course the smaller the room the less gas will be consumed to heat it to the desired temp
    Most oil filled heaters are between 3/4 and 2 KW with variable settings, you will find the size of yours on a label attached to the heater,these can not be run of batteries
    Given the climate your going to and the possibilities of no hook up I would carry a small generator approx 2 kW, a fraction of the cost to run than the main on board one unless your main Genny also runs on LPG
    Geo
    ps another thing to find out is to see if on board genny will start with very low house battery and check if battery link relay works, Mine didnt!!!!
  5. scotjimland
    Jul 25, 2007
    28,936
    25,589
    Hi Andy
    I wouldn't consider going to a winter location for any more than a couple of days without a 16A hook up..
    As Geo says, blown air gas heating is good but it eats batteries, and drinks LPG at an alarming rate.
    A 2kw genny would be on for several hours a day just to keep the bateries charged, that's assuming you have a decent charger, most RVS come ill equiped in the charger department, .. IMO a genny isn't a viable option in winter.
    I recomend fitting two oil filled wall mounted panel heaters, around 800 watt each, this will keep the temp about 10 deg above ambient .. extra heat can be provided by using a portable fan heater on low power, and as a last resort use the gas blown air to boost the temp up to a comfy 22c
    Another tip, fit an electric blanket .. :thumb::thumb:
  6. Tandy
    Tandy Funster
    Jan 13, 2008
    73
    14
    Cardiff
    Thanks for the advice Geo,
    So to sum up (hopefully):Wink: :-
    Furnace will work great but running out of propane isn't what should concern me it's running out of battery power needed for the fans that the furnace needs!!
    The oil filled heater is no good unless I can hook up to the mains (or want to run the generator)
    Darren (from motorhome medics) checked out the RV and arrange for the coach and engine batteries to charge up no matter the source and if needed (because the coach battery is flat) the engine battery can be used to start up the genny (which runs on petrol ...I think).
    Don't think the misses will let me buy anything at the moment, so I'm just wishing and dreaming about what I could/should/hope to buy :BigGrin:Andy
  7. dylan
    dylan Read Only Funster
    Aug 31, 2007
    4,162
    569
    sw wales
    We fit Efoy systems at work, the boss has one fitted in his new Swift and swears by it. :thumb:
  8. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,704
    17,321
    YO11 2BD
    Mmmm..........bet the boss also got it at cost price as well !!!!:Rofl1:
  9. scotjimland
    Jul 25, 2007
    28,936
    25,589
    He may well do, but £2.5k buys a lot of nights on ehu.
  10. dylan
    Aug 31, 2007
    4,162
    569
    sw wales
    Errrrrrrrrr don't think its that much money !
  11. scotjimland
    Jul 25, 2007
    28,936
    25,589
    Category: Power on the move
    Manufacturer: Efoy (SFC)
    Price: £2,579.00
    SKU: EFOY FUEL CELL 1200
    see above link
  12. olley
    olley Funster
    Jul 29, 2007
    3,746
    2,189
    Ipswich
    Hi their was a big thread about the EFOY on the "other" site last week, general consensus was; buy a genny :BigGrin:
    According to eddie vanbitz who used to flog them, its the availability of the methanol cartridges that's a big problem, only about 40-50 dealers stock it, and it can't be delivered, pick up only.
    The situation abroad is better, but not ideal, 1 cartridge will last about a week apparently.
    DAB reckons on waiting until Truma LPG fuel cells become available late next year.
    Olley
  13. dylan
    Aug 31, 2007
    4,162
    569
    sw wales
    Jim, I will check on our price but didn't think it was that much:Smile:
  14. dylan
    Aug 31, 2007
    4,162
    569
    sw wales
    Reply from work:
    Eileen, There are four power outputs of the Efoy, 600, 900,1200 and 1600. We
    use the 1600 unit which generates 5.4 amp when needed. The two best sellers
    are the 600 and the 1600. On all units we offer free fitting (max 2 hours)
    and a free 5 litre cartridge of fuel. So on each Efoy unit there is a saving
    of £100. Our unit has run for 120 hours and used 3/4 of a 10 litre fuel
    container. There is very little noise, on fact we sleep on the bed over the
    Efoy unit and cant hear it.
    600:- £1649
    900:- £2099
    1200:-£2599
    1600:-£2999
    5 litres of fuel:- £17.99
    10 litres of fuel:-£26.99
    We have also developed a way of putting the output of the Efoy back into the
    charging/240v system with the use a high power inverter. However this is
    costly and not really needed. We have also fitted more Efoy systems than
    anybody else in the U.K!!
    Seems right Jim - sorry only had price for smaller system in my head. Boss is happy to answer any questions from members and I will give mobile phone number by PM if asked. :Smile:
  15. scotjimland
    Jul 25, 2007
    28,936
    25,589
    Thanks Eileen for your detailed and informative reply ..
    Jim
  16. Douglas
    Douglas Read Only Funster
    Aug 22, 2008
    2,837
    401
    South Wales,
    The social side of generators
    Hi all
    We wild camp 99.9% of the time and we do come across the odd generator or two, my thoughts, and this seems almost universal amongs the people we meet who dont have generators, is that they are a bloody nusiance and they are used by people who dont give a dam for anybody else. but of course this is a personal view and we are not all the same, I have my tin hat on waiting........ Hi HI.
    Doug and Sandra.
  17. Stephen & Jeannie
    Stephen & Jeannie Read Only Funster
    Aug 27, 2008
    4,198
    3,261
    Gobowen near Oswestry !!
    TIN HAT not needed ! you have only said what every one else on this site thinks ! by the way what boat ? i had a 32 ft. sadler in Dartmouth for a couple of years .....and,,,,i like the HooPoe !!!! regards Stephen. :Wink:
  18. scotjimland
    Jul 25, 2007
    28,936
    25,589
    Never knew you were clairvoyant... :RollEyes:
    I for one happen to disagree, but I won't be drawn into an argument about the pros/cons of gennies, live and let live is my motto, if I don't like something I move on..
  19. Douglas
    Aug 22, 2008
    2,837
    401
    South Wales,
    Ah! but what about if I am there first, I have found the the people who use generators are blind to the nusiance they course. Do I have to leave or what?
  20. scotjimland
    Jul 25, 2007
    28,936
    25,589
    see above.. :Smile:
