Ec 840 Woes
Discussion in 'Motorhome Chat' started by Nik, May 2, 2015.
  1. Nik
    Nik Funster
    Oct 29, 2014
    125
    82
    Surrey UK
    Hi.
    My EC840 display in my Autotrail has frozen at 0855, it's now 2220. We had a power EHU problem and the system went off. Having turned things back on the display is now frozen and I cant change anything. I cant get to the Autotrail logo to try a reset. I have switched everything off and gradually brought power back to the various systems. My ec500 unit seems ok having done the initial test following hookup. Water, heating, lights, water pump are working ok but I can't get any electric/water ' level bar graphs'. I just get a beep when I press any of the buttons on the right of the display.
    Any advice grateful received.
    Best regards.
    Nik
  2. Gellyneck
    Gellyneck Funster Life Member
    Jun 5, 2014
    1,513
    2,086
    Scotland
    Have you tried doing a full system shutdown or holding down up \ down buttons until the Dealer Setting menu comes up?
  3. vin0114
    vin0114 Funster
    Feb 8, 2014
    711
    684
    Sheffield
    Try disconnecting EHU then full shutdown ec500, wait 5mins then power up ec500?
  4. Nik
    Nik Funster
    Oct 29, 2014
    125
    82
    Surrey UK
    Thanks both.
    I have tried pressing and holding the control buttons, it beeps but nothing else happens. I will again try a full disconnect and shutdown a bit later when it stops raining here in Sunny? Hastings.
    Thanks again.
    Nik
  5. mike mcglynn
    mike mcglynn Funster Life Member
    Jan 6, 2008
    1,408
    5,251
    St. Helens MERSEYSIDE
    Hi. Nic in my autotrail when the control panel freezes up I disconnect it from the power for a few minutes 2 small screws and a plug to come off let it rest for a few minutes and when you put it back together you should hear a little beep then everthing goes back to normal.
  6. vin0114
    vin0114 Funster
    Feb 8, 2014
    711
    684
    Sheffield
    Any luck yet Nik?
  7. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,584
    22,495
    Narrfoook
    If all else fails, click the front bezel off, remove the screws that hold the panel in place, and gently pull the main plug out of the panel
    leave on the side for a while, then refit
  8. Gellyneck
    Jun 5, 2014
    1,513
    2,086
    Scotland
    Would the shutdown mode on the main panel not achieve same, John?:unsure: Dealer told us it powered down everything except the alarm \ tracker but would believe a man who's disconnected and recollected every wire with enough left over for, eh......., over them.:)
  9. Jaws
    Sep 26, 2008
    18,584
    22,495
    Narrfoook
    No mate.. It would if the thing had not locked up but with the wee processor all baffled it is unlikely
    Some panels also have a button battery ( mine has not but a lot do ! ) if you have a button battery hook that out too !
    • Like Like x 1
  10. Nik
    Nik Funster
    Oct 29, 2014
    125
    82
    Surrey UK
    Hi All.
    Turned it all of, drove up to Bodiham Castle for a few hours and when arrived back on site turned all back on and hey presto all appears ok for now and back to normal.
    Thanks all for your help,panic over.
    Cheers.
    Nik
    • Like Like x 1
  11. vin0114
    vin0114 Funster
    Feb 8, 2014
    711
    684
    Sheffield
    That's good news Nik, will remember fix for future:)
