Eberspatcher question part 2
Discussion in 'Motorhome Chat' started by ips, Jul 30, 2009.
  1. ips
    ips Read Only Funster
    Jul 3, 2009
    506
    3
    What is the economy of these diesel fired blown air heaters ie. how many litres or ml per hour. I know it depends what yer stat is set at and how much you use em but as a rule of thumb ?????
  2. forfourgeek
    forfourgeek Read Only Funster
    May 21, 2009
    20
    Forest Of Dean
    Suggest you visit the Eber ' web site. If you are thinking of buying.
    Eberspächer UK - Air Heaters Airtronic D2
    Identify your heater in the list, then all the info you need should be there.
    My own experience of Ebers is awful. I personally prefer Webasto. I had more luck with Webasto.
    Webasto Caravan :: Heating
    But, it is only fair to say, that both heaters must be installed exactly as per manufacturers instructions. Ive had both installed in boats the eber was dire. Having said that, there are thousands out there that perform brilliantly for many years.
    Be sure too that what ever you buy is installed by a reputable firm. Contact Webasto uk and get confirmation that your installer is recognized by them. You could do it yourself, its not rocket science, but please stick to the instructions.
    Sorry about the rant. But ive lived with these heaters for years, and learned a lot about both, enough probably to write a book.
  3. keith
    keith Funster
    Aug 25, 2007
    3,286
    1,672
    Ecclefechan
    We have one, fitted from new, & very pleased with it. Eberspacher (spell?) that is. :thumb:
    Can't give you detailed usage figures but the fuel gauge never seems to go down when we use it, even in winter. I was told by the dealer we got the van off that they were very economical & I have no reason to doubt him from our experience. :BigGrin:
    They are possibly more noisy than a gas heater, especially on start up, & of course use more leccy but once running very easy to live with.
    Being diesel you don't have to worry about running out, very useful if in Spain where gas bottles can be a problem to get filled.
    I believe the initial cost is quite high.
  4. ips
    Jul 3, 2009
    506
    3
    Just to clarify matters..........eber is allready installed in our new MH. Was just wondering if I could afford to put it on......:BigGrin:
  5. keith
    keith Funster
    Aug 25, 2007
    3,286
    1,672
    Ecclefechan
    Try it :thumb:
    My experience is that it won't cost you a fortune. :BigGrin:
  6. ips
    Jul 3, 2009
    506
    3
    Had it on a couple of times in the evening when it goes a bit chilly, on for less than an hour each time so couldnt tell exactly but didnt seem to move my fuel guage. Certainly seems efficient.
    Ian
  7. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    approx 10 hours on 1 litre, can't be bad.
  8. ips
    Jul 3, 2009
    506
    3
    ooooh that is good, were's that info from ??
    Maybe I can afford to put it on then :BigGrin:
  9. Wildman
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    from the eberspatcher info disc.
  10. ips
    Jul 3, 2009
    506
    3
    Thank you for the info...very economical arent they. ?
  11. alf
    alf Read Only Funster
    Apr 7, 2009
    69
    South Yorkshire
    Assuming it is a D2 heater. Eberspacher quote .23ltr per hour for a large motorcaravan ie coachbuilt for a small PVC .10ltrper hour if you got the Airtronic installation instructions look at page 12/13 if you turn the themostat slowly untill you hear the click leave it there the heater will build up to full then automatically reduce to 3/4 power to maintain temperature if you leave thermatat at full it will use more deisel.
    Regards
    alf
  12. duetto owner
    duetto owner Read Only Funster
    May 7, 2009
    216
    north surrey
    our eber comes with duel fuel option mains or diesel, does not seem to use much diesel when used that way compared to the large amout of heat it can produce, when on site's use mains hookup to run it which is silent now ebers fixed that knocking noise.
    very please which the heating system came as standard in our duetto.
  13. ips
    Jul 3, 2009
    506
    3
    Thank you for the info gentlemen. Unfrotunately mine only works on deisel but sounds like I can afford to keep Mrs ips warm this winter. :BigGrin:
  14. jezport
    jezport Funster
    Oct 29, 2008
    1,892
    1,275
    West Yorkshire
    We have one in our Flash 03 and it works fine and uses very little diesel. Make sure you run it regularly to keep it running ok.
  15. Wildman
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    Hi I'm not sure why you split your posts into part 1, 2, etc just go back and post again in the original thread makes it much easier to follow.:thumb::thumb:
  16. warwick
    warwick Read Only Funster
    Sep 16, 2008
    113
    You won`t have to worry about cost, far better than gas heaters on that point, used ours for the first time last winter and it really is quick and efficient.
  17. slickmouse
    slickmouse Read Only Funster
    Dec 30, 2007
    305
    Planet Mars next 2 Uranus
    Install a seperate tank and run it on Red diesel, its what I have done, put in a wee inline filter.
  18. Neckender
    Neckender Funster
    Oct 15, 2007
    1,272
    1,589
    Neckend or Benidorm
    We have one in our motorhome used it a full week end once and the fuel guage didn't seem to move, very economical.
    John.
  19. ips
    Jul 3, 2009
    506
    3
    Your probably right...............sorry. :Doh:
    Ian
  20. Wildman
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    No worries we were all new once. Just keep posting, hee hee
