Eberspacher diesel heater pump ticking on Chausson Flash 10 (1 Viewer)
Apr 19, 2014
92
43
CHESHIRE
A CLASS
1 YEAR
Chausson Flash 10
This is really annoying as you can hear the pump ticking at night when the heating is on . Anyone got a solution before I fork out thousands at a dealer to sort it out?
Woooody
andy63
4,672
15,017
south shields
None
since 1990
got the eberspacher hydronic heater on my van and can hear the same noise you describe (ie a tick or knocking)
when it starts up but not while its running as I think the noise of the burner and internal heating fan drown out the pump noise once it fires up. that is the noise the diesel feed pump makes.. surprised you can hear it once the heater fires.
ta andy
Nov 25, 2013
1,114
1,753
kent
Swift Kontiki 669
Since April 2013
Its probably the noise of the electric pump .
Martin
Mar 23, 2012
9,532
31,993
sleights
c class
Same sound on ours think its just the way they are did see a post a while ago saying they put some sound insulation in to deaden the noise but not sure where.
David
May 29, 2013
2,589
19,167
Tyneside
Chausson best of Flash 10
Several years now
Earplugs............................with added benefit of filtering out any snoring in the vicinity !!
Having said that, once we're under the covers on the bed, the last thing we'd want is any more heat in the van.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
It's the dosing pump which should be mounted in a rubber bracket but even so it is audible all the time.
andy63
4,672
15,017
south shields
None
since 1990
if it is the later hydronic heater the pump is incorporated in the heater unit. the only solution to prevent the knocking noise would maybe be rubber/flexible mounts on the heater mounting. think the earlier units had an external pump which you might be able to insulate.
ta andy
Feb 4, 2010
2,329
1,590
Mid. Glamorgan, S. Wales
Motorhutch / Toy Camper
Since 2010
