EBERSPACHER D2 AIRTRONIC - Diesel Heater (1 Viewer)
Zozzer
76
Leigh, Lancashire
Van Conversion
Not Long Enough
Tried to use the Espacher D2 Heater in our Symbol this weekend but it's failing to fire up. The fan works fine but the heater doesn't. Anyone any idea's ?
As I hadn't use the heater for many months I was thinking that maybe
the diesel in the pipes was the summer variety and had waxed up.
Is this plausable ?
Regards
Zozzer
thehutchies
1,527
1,776
The Wheelèd Shed
Hi Zozzer,
Have you tried disconnecting the fuel pipe at the heater unit or on the heater side of the pump?
If you can hear the pump operating (loud ticking) when the heater is turned on, then you should be able to see the diesel pumping through.
Regards,
Andrew
