EBERSPACHER AIRTRONIC (1 Viewer)
octopush
147
54
portsmouth
coachbuilt
2days
when I last turned on my EBERSPACHER Heater it worked for about 5 mins then smoke filled the motorhome fom all the vents.
I turned it back on but it did not work any moor.
I think I have found the fuse for it in the battery box the fuse had blown so I replaced it but it just went again.
I am going to have a look tomorrow if the rain has gone as it's under the van in a box.
The control for the heater still lights up but that's all.
Anyone have an idea what's wrong with it
Rob
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Just an educated guess, but I would say your air circulation fan motor has burned out.
Possibly due a blockage or just a seized bearing?
Nov 30, 2009
6,545
148,888
Pickering
PVC the PUG
With the Webasto you get an error code . A light flashes in a sequence then a booklet you get with the van tells you what's wrong. I don't know if erberspacher the same ?
Apr 9, 2013
663
373
Ayr
Newbie
Rob
This site looks useful.
http://www.letonkinoisvarnish.uk/eberspacher_faults_2.html
Having said that, smoke coming from the vents doesn't sound good. Maybe fan motor burnt out?
Don Quixote
2,966
5,258
Lost in La Mancha, Spain
VW T6 Campervan
Not sure this will help you as this is from my Webasto setup.
You need to do some flashes counting.
Extract from the manual is below.
The five is just a warning.
The number of rapids indicates the fault.
Most are remedied by turning the thing off for 5 minutes and trying again. Especially if it has not been used for some time.
"Self-Diagnostic System" (Reading Flash Codes)
A flash code will be generated on the indicator light of the control element. These flash codes indicate a
malfunction and subsequent operational interruption. There are up to ten codes available depending on
the nature of the malfunction and the heater model (see Table 2).
In order to make a correct analysis, it is necessary to understand the flash code event. The flash code
pertains to the control element (switch) only. The flash code is only visible during the after-run (cooldown)
period of operation (an optional timer will hold the last code in memory until corrected, see “F”
codes in parentheses on Table 2).
During the flash code event, you will see five quick flashes followed by a slower sequence of flashes from
one flash up to ten flashes. The slower sequence of flashes is the actual malfunction code. The five quick
flashes are only an indication that a malfunction has been detected and that the code will be displayed.
Count only the slower sequence of flashes to obtain the current malfunction code.
For example ( = one flash):
Event code 4X (F 04): ... ... ... ...
The fast/slow sequence will be repeated until the heater completes the after-run (cool-down) cycle after
which, the code will be stored in the control unit memory.
No Function Electrical wiring, fuses
Control unit
Fuses, battery connections
Power at red wire, ground at brown wire
Control unit malfunction
1 x Flash (F 01)
No start after 2 start
attempts No flame-up
Fuel system
Combustion air
Burner
Fuel level - No fuel - Fuel system not primed
Type of fuel being used
Plugged fuel filter - replace
Fuel line connections and clamps loose
Air intake or exhaust - restricted or plugged
Clean or replace burner unit
2 x Flashes (F 02)
Flame-out during
operation
Fuel supply (shortage)
Burner
Restriction in fuel system
3 x Flashes (F 03)
Low or over voltage for
more than 20 seconds
Electrical system Load test batteries
Corrosion at connections
Loose connections
4 x Flashes (F 04)
Premature flame
detection
Defective flame sensor
Defective flame sensor/
glow pin
Replace flame sensor - Air Top 2000 S only
Replace flame sensor/glow pin - Air Top 3500/5000
only
5 x Flashes (F 05)
(Air Top 2000 S Only)
Flame sensor
Wiring
Damaged or corroded wiring, open or short circuit
6 x Flashes (F 06)
Temperature sensor
Wiring
Defective temp. sensor
Replace temperature sensor
7 x Flashes (F 07)
Fuel metering pump
Wiring
Defective fuel pump
Replace fuel pump
8 x Flashes (F 08)
Combustion air fan
Wiring
Wrong RPM
Defective fan motor
Replace combustion air fan
9 x Flashes (F 09)
Glow pin
(Ceramic igniter)
Wiring
Defective glow pin
glow pin
Replace glow pin - Air Top 2000 S only
only
10 x Flashes (F 10)
Overheating
Overheating
Air flow
Wiring
Defective temp. limiter
Switch heater off and back on (see air flow)
Motor/fan obstruction, heating air flow blocked
Replace temperature limiter
11 x Flashes (F 11)
(Air Top 3500/5000 Only)
Temperature limiter
Wiring
12 x Flashes (F 12)
Control element
Wiring
Defective control element
Replace control element
octopush
octopush
147
54
portsmouth
coachbuilt
2days
wright I have taken it out from under the motorhome.
That's a job on its own.
I have tested the fan by putting power to it and that's ok.
I'm now thinking it could be a faulty censer but would that blow a 20 amp fuse.
my be a heater plug.
octopush
octopush
147
54
portsmouth
coachbuilt
2days
I think this May be the problem.
That would explain the smoke coming out the vents.
Any idea were to get one cheaper . Ebay £240
I'm sure it's not going to be cheep
Don Quixote
2,966
5,258
VW T6 Campervan
My word thats lucky it did not start a big fire. Before doing anything email the makers and explain you are looking at taken legal action as it was a near disaster. They may tell you to "take a hike" or they may give you a replacement and ask for that one back for tests etc..... If you don't ask you will never know.
octopush
octopush
147
54
portsmouth
coachbuilt
2days
Thanks for your advice I have just sent them a email.
I will let you know what they say.
octopush
octopush
147
54
portsmouth
coachbuilt
2days
This is the reply I got from them.
Thank you for your email
For us to investigate further we need more information.
It appears to be an ICU dating back to pre-2005.
Please supply:
Heater No. 25 ???? ??
Fabric No.
Date of purchase:
Installation date:
Location of heater:
Details of duct arrangement (length, bends, outlets) a sketch would be helpful:
Wiring size:
Fuse ratings fitted:
Service history and Eberspacher Dealer who performed:
Vehicle details:
Thanking you for your assistance
Kind regards
Gini Turner
I bought the Van second hand so it will be hard to give them all the info they want and I bet they know that.
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Knowing the cost of parts for these things, a new heater might be a smarter move.
At least everything will be new.
A faulty motor could have caused the transistor to overheat which caused the fire.
Changing just the ECU might just result in another burnt out ECU.
Don Quixote
2,966
5,258
VW T6 Campervan
There is always the "cop out" and they know that. I would fully agree with JohnandShell and get a new one as that way you have fully warranty. I cannot comment on the EBERSPACHER heater, but the Webasto we have fitted is very good. It does not heat the water as well, however we have the gas to do that so not worried.
Good luck whatever route you go down.
octopush
octopush
147
54
portsmouth
coachbuilt
2days
I agree but I have a few months before it gets really cold I will have a look around and see if I can get one second hand.
in the mean time I will se if there is another way that is better to heat the motorhome.
Thanks for the advice.
Don Quixote
2,966
5,258
VW T6 Campervan
Rob, a little 800watts mains heater will work if you're going to be on EHU until you get sorted.
keith
3,421
1,864
Ecclefechan
Autocruise Starseeker
in the mean time I will see if there is another way that is better to heat the motorhome.
I don't think there is IMO. We have been very pleased with ours and would definitely have another just for the convenience of not having to think about the gas consumption.
