E + P levers (1 Viewer)
rrusty
258
212
Scotland
None sold sept 2019
jacks will not work because control panel light says the hand brake is not on but it is. Can anyone help please.
funflair
19,331
30,170
Guisborough
MORELO palace
since 2012
Check the hand brake switch is contacting, does it put a light up on the dashboard when its on?
Martin
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
Mine is also linked into the Dashboard warning light!
Feb 24, 2013
13,073
101,435
Bolsover, Derbyshire
Hymer S800
not long enough
we have a similar light comes on if the system thinks the ground is too far out of level to work, we can still use in 'hand' with that light on though
R
rrusty
258
212
Scotland
None sold sept 2019
Thanks folks, I will have a look when I get back tomorrow, if it is not would a garage mechanic sort that or would it have to be E+P
Feb 24, 2013
13,073
101,435
Hymer S800
not long enough
it will need a specialist E + P man I would think, I presume it is not new or you would go back to whoever fitted it, might be worth just pulling the fuse and doing a reset (y)
R
rrusty
258
212
Scotland
None sold sept 2019
Only marginally of the level
Feb 24, 2013
13,073
101,435
Hymer S800
not long enough
we have had a couple of odd occasions where ours wouldn't deploy due to 'level' despite being nearly flat, I suggest you try in hand, then reset it, then kick it :) does yours have a remote control? if yes maybe check those batteries?
Feb 24, 2013
13,073
101,435
Hymer S800
not long enough
As a break away post, but still on E + P's, our installer Mick SAP Doncaster suggested to me to use hand rather than auto levelling as in auto it always lifts higher than actually needed for no real reason
funflair
19,331
30,170
Guisborough
MORELO palace
since 2012
I have found the same as David.
Martin
funflair
19,331
30,170
Guisborough
MORELO palace
since 2012
I would have thought that a decent Auto electrician or mechanic could check the wiring to the handbrake, but after that it may well be a service job.
The basic layout schematic is on page 26 of this
Martin
funflair
19,331
30,170
Guisborough
MORELO palace
since 2012
Don't have a remote.
You will have the basic wired panel then, we have that but on a trailing lead rather than fixed and then we have the wireless remote as well.
Martin
Feb 24, 2013
13,073
101,435
Hymer S800
not long enough
have you tried using it in hand instead of auto, presuming you have both options?
if the hand brake light is on I would have thought the problem is in the E + P side (somewhere)
R
rrusty
258
212
Scotland
None sold sept 2019
It won't work in hand or auto, but just checked and the hand brake light is not on.
Some thing else now the remote key will not unlock the steering but the spare key will.
funflair
19,331
30,170
Guisborough
MORELO palace
since 2012
suggests its possibly the handbrake switch or the wiring to it.
Martin
