E l e c t r i c k e r y
Discussion in 'Tech/Mech General' started by stcyr, May 10, 2012.
  1. stcyr
    stcyr Funster
    Apr 11, 2011
    1,681
    1,115
    Normandie
    Just wondering if anyone can throw some light on why when we are on EHU 1) The green telltale on the control board lights then immediately goes out when we switch on the mains switch - and 2) the hab.battery monitor shows 15 or so (charging) ...
    but when using the generator (1kw invertor) 1) The green telltale stays on and 2) The hab.battery monitor only shows same as when on just solar???
    Everything works the same on both options.
    :RollEyes:
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,098
    17,766
    YO11 2BD
    Sorry, you lost me at 'green telltale'.
    what is it supposed to indicate, as you say it goes out when on 230v hookup
  3. stcyr
    stcyr Funster
    Apr 11, 2011
    1,681
    1,115
    Normandie
    It's a "Bord-control" panel with 3 circuit breakers, 12v on/off, tank & battery level guages etc., and a little green light which normally lights up and virtually immediately goes out when on EHU. We have only just started using the generator down on Wildman's site and only just noticed that for some reason this green light stays on. Just puzzled as to why it should behave differently on EHU (230v) to generator (230v). I'd expect it to behave the same? Also, as I said, on EHU the battery monitor goes up to 14 or 15+ but now on generator it is showing same as on solar. Just concerned generator may've affected the charger in some way ... :Smile:
    (1991 Dethleffs, same as Hymer...)
  4. pappajohn
    Aug 26, 2007
    30,098
    17,766
    YO11 2BD
    could be because the genny doesnt have a true earth...only an internal earth.
    some control panels even show this as reversed polarity when on a genny for some reason.
    • Like it Like it x 1
  5. Gromett
    Gromett Funster
    Feb 27, 2011
    8,174
    15,001
    UK
    I agree with PapaJohn as that being the most likely cause.
