dumped fuel
Discussion in 'Fiat' started by cranky, Jul 29, 2015.
  1. cranky
    cranky Funster
    Oct 29, 2012
    399
    455
    essex
    after a lovely weekend (apart from sitting in a ten mile tailback at the Dartford crossing) got home parked up, moved my car off the drive to put M/H on ,started up and within seconds could smell diesel, parked up and could see diesel dripping from engine bay. switched off and checked under bonnet and it appeared to be coming from fuel filter. let the old girl cool down and wiped everything clean, started up an hour later and all appears normal, no leaks! could it have just been sitting in the traffic for a couple of hours? any ideas? your thought appreciated.
    C
  2. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    fractured overflow/return pipe from injectors would be my guess
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,700
    17,316
    YO11 2BD
    Fiat ducato ?
    Cracked filter housing, a common fault and not too expensive for a complete new housing.
  4. cranky
    cranky Funster
    Oct 29, 2012
    399
    455
    essex
    Cheer PJ I have been doing a bit of searching and found all the threads. do I assume it will start chucking it out once it gets warm as it seems ok at present but I only ran it for 10 minutes?
  5. cranky
    cranky Funster
    Oct 29, 2012
    399
    455
    essex
    thanks Wildman, will check them as well.
  6. pappajohn
    Aug 26, 2007
    29,700
    17,316
    YO11 2BD
    Dont really know the ins and outs but i would expect heat expansion would cause it.
  7. cranky
    cranky Funster
    Oct 29, 2012
    399
    455
    essex
    cheers PJ. will have another look tomorrow.
  8. Allanm
    Allanm Funster
    Jun 30, 2013
    3,115
    4,247
    Cotes d'armor, France
    If its anything like the filter in my car, ( as I found out after I changed it a few weeks ago) it gets very hot after a good run. Don't know where the filter is in the van to check.
  9. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    5,535
    5,623
    West Sussex
    Yep agree sounds like fuel filter housing cracked, common on early x250's.
  10. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,185
    14,954
    Leeds the one up North
    What year is the van?
  11. Techno
    Jul 28, 2010
    14,185
    14,954
    On the fire wall behind near side headlight
    [​IMG]
    • Like Like x 1
  12. DuxDeluxe
    DuxDeluxe Funster Life Member
    Jul 10, 2008
    9,439
    25,441
    Planet Zog
    A common issue (happened to me twice) is the fuel filter seal which can leak when hot - this is why it doesn't leak after you stopped for a while. The torque required to screw the top of the housing is quite high and it is easy to crack the housing as well. A lot of threads about leaking X250 fuel filters on here and a lot of advice. Later ones had modified filter design.
    My money is on the leaking seal. Cheers
  13. Allanm
    Allanm Funster
    Jun 30, 2013
    3,115
    4,247
    So it is, thanks..... mine has a black top :(.
  14. DuxDeluxe
    Jul 10, 2008
    9,439
    25,441
    Planet Zog
    My leaking ones were all black as well. The RAC man in both cases removed the whole filter housing, cleaned it, pointed out the lousy seal design and put it back together, fixing the leak in each case until the Fiat "professional" garage serviced the vehicle - seal started leaking a couple of weeks later in both cases
  15. cranky
    cranky Funster
    Oct 29, 2012
    399
    455
    essex
    thanks for all your replies. It is an 07 model and the same as in Techno's pic. I will check it out at the weekend.
  16. Techno
    Jul 28, 2010
    14,185
    14,954
    • Like Like x 1
  17. bubble63
    bubble63 Funster
    Aug 10, 2012
    533
    472
    cambridge
    Chuck yours
    Fit a new one and carry a spare new one
    My correctly serviced one failed AGAIN after only 500 miles
    Yes....... Torqued up with correct tooling!!
    Stupid item!!??
    Oooooo forgot to say recovery man did £2000 worth of damage on the first recovery
    Second failure I changed the filter myself in 10 mins, no tools
  18. Mr Colpot
    Mr Colpot Funster
    Apr 29, 2009
    695
    249
    West Sussex
    Ours went (07 van) last year - AA Guy came out and fitted new seal (£9) and hasnt been a problem since.
  19. Bobby22
    Bobby22 Funster
    Dec 15, 2013
    1,099
    3,408
    Scotland
    Have you had it checked yet? Any outcome/result
  20. bubble63
    bubble63 Funster
    Aug 10, 2012
    533
    472
    cambridge
    Yep the deal will seal but 500 miles mine went again
    Fit a new one and carry a new spare !
Similar Threads
  1. Louis
    64
    2,590
