Ducatto Mirror parts
Discussion in 'Motorhome Chat' started by alcorn54, May 2, 2011.
  1. alcorn54
    alcorn54 Read Only Funster
    Nov 21, 2010
    283
    6
    Co Durham
    Some clod walloped my passenger side mirror last week whilst in wales and didn't hang about.Resulting in a damaged swivel bracket, on top arm passenger side. Basically if you take top arm outer plastic covers of the mirror arm, all it is basically, is a pipe that slides over a lump of round cast metal which is part of the bracket and held in place via a small bolt. The bracket has snapped off where the pipe connects. The top bracket is then held in place by one single screw. I have manage to tie wrap the top arm together and replace covers ,and it looks fine but I need the top arm inner swivel bracket . Anybody any idea where I can get the bracket or must I buy a complete mirror .
    Alan
  2. peter marshall
    peter marshall
    Mar 5, 2009
    2,702
    1,701
    Cleveleys,Lancashire
    Hi Alan
    I hit my mirror same type as yours, bracket ok, but knocked all the plastic backing of the bottom ,tried to buy a new mirror but could not source one, so finished up rebuilding with car filler etc, not a bad finish, so it will do until next time lol, try the mirror man on the internet for your bracket or take it to a welder if poss, pete :thumb:
  3. alcorn54
    Nov 21, 2010
    283
    6
    Co Durham
    It cheap cast and the lug the pipe slides over has come clean of,dont think it would weld?? ,I can remove the damaged bit without having to take full mirror off,only held in place by one screw. . If I cant source a new bit ill just leave as iss as you can see tie wraps behind plastic cover.
    Alan
  4. Douglas
    Douglas Read Only Funster
    Aug 22, 2008
    2,837
    401
    South Wales,
    I too have had damage to a Ducato mirror, and fiats do not supply spares only a complete assembly.
    Doug...
  5. steveclecy
    steveclecy Read Only Funster
    Jun 10, 2009
    885
    582
    Wirral
    There were some good links given by Funsters on this post. You must have met the same person I did in Wales!
    Steve
  6. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,069
    DERBYSHIRE
  7. alcorn54
    Nov 21, 2010
    283
    6
    Co Durham
  8. Douglas
    Aug 22, 2008
    2,837
    401
    South Wales,
    I doubt if its gunmetal, gunmetal is a kind of bronze and is a brass colour, its more likely to be a aluminum alloy, I have the bits left over from my broken unit, but like you its broke at the joint on the arm.
    Doug...
  9. Masman
    Masman Funster
    Sep 25, 2009
    313
    205
    south yorkshire
    HAVE YOU TRIED PLASTIC METAL. IT USED TO BE AVAILABLE FROM CAR ASSESORY SHOPS.USED IT SOME TIM.E AGO. IT IS VERY STRONG.:thumb:
  10. alcorn54
    Nov 21, 2010
    283
    6
    Co Durham
    Hi Doug your right ,it looks like a cast alloy ,silver on color,tried gluing it with two pack plastic metal but just snapped again cross the joint. Alan
  11. jhorsf
    May 15, 2009
    9,156
    8,069
    DERBYSHIRE
  12. peter marshall
    peter marshall
    Mar 5, 2009
    2,702
    1,701
    Alan
    Could you slid a bar in to the broken part's drill and screw both side with self tappers . Pete
  13. alcorn54
    Nov 21, 2010
    283
    6
    Co Durham
