Ducato window problem (1 Viewer)
Vlad The Impaler
1,633
2,227
Rutland
Since 2012 but longer in my dreams
I had a service and 2new leisure batteries fitted yesterday and since then passenger window has stopped working.Driver window works as normal but just getting a click noise from dash when pushing button.
The window stuck halfway down yesterday so I took door card off and managed to find a garage, no mean feat at 4 on a Saturday afternoon.The mechanic tells me there is power to the switch and the motor,he used a probe thing and got the motor to work closing the window.
Anyone had this happen or have an idea of what's going on.Its a 2004 Fiat Ducato
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
I know that click, it's the computer sensing all is not well and turning off the motor.
So duff motor or in need of lubrication or recalibration.
There is a recalibration sequence for the computer to learn the motor's current, but I've forgotten what it is.
In our case the window would not open at all, but eventually did and now I make sure I open it regularly.
Vlad The Impaler
Vlad The Impaler
1,633
2,227
Rutland
Window
Brian when you say a duff motor do you mean broke,mechanic got it working to close it so assume its ok.What do u mean by Re calibration and lubrication is that something only to be tackled by a garage
Jaws
23,836
72,474
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
This may seem off topic, but was it working before the service and batteries were done ?
Vlad The Impaler
Vlad The Impaler
1,633
2,227
Rutland
Windows
Yes all working fine. Problem only after could it be there fault
Jaws
23,836
72,474
Thetford Norfolk
C class, Chieftain
I would be down on them like a ton of bricks..
Start screaming CAB and small claims courts.. Works wonders..
Would also be interested in where you had it done.. Others can then avoid using the place !
Vlad The Impaler
Vlad The Impaler
1,633
2,227
Rutland
Windows
Would working on the leisure batteries affect the electrics on the van?
If anyone has any thoughts on this I'd like to know,might give me some ammo when I go in tomorrow if I can know what I'm talking about
ticktok
41
Kent (South Coast)
Swift
5 Years
I have no doubt someone will explain but how can changing the leisure batteries affect the window winders that run from the van batteries.
I have the same problem with a 03 Ducato and the passenger window has stopped working, I also can hear a click but assumed it was the relay as it seems to come from that area.
TheBig1
17,630
43,272
the easiest reset method is to disconnect the van battery for 1/2 an hour so clearing the memory. this may be what triggered your problem, as probably the garage disconnected the battery for safety
whilst battery is off, take the time to remove the door inner cards and lubricate the motors an pivots. once the battery is back on, drop each window all the way then close,again all the way. this restores the correct open and closed points in the body control modules memory
Jaws
23,836
72,474
Thetford Norfolk
C class, Chieftain
My issue is not with the battery change but the 'service' which was mentioned by the OP.
